(the problem was I had checked multi ap isolation in my router).t.
Thats new, whats multi app isolation?? Never heard ....
Used the same card just changed the bracket after removing the vga port.Congratulations on your new HTPC. :clapping:
I'm quite curious to know what you did with the graphics card, did you exchange it or you exchanged the case?
Muti-AP (AccesPoint) is what he meant I think ...
G0bble
Looking at buying this graphics card as I realised while the motherboard says HD Audio its analog as also the support for HD video.
Forsa NVIDIA GT630 1 GB SDDR3 Graphics Card - Forsa: Flipkart.com
I guess this should be enough for BD ISO/ 3D/DTS HDMA and DD TruHD.
hi sud98, can you play the 3d iso files without any audio sync problem?
If you have any audio sync problem, U have to use 'ReClock' (Open source app.) from Videohelp or 'VideoClock' (Excl. comes with JRiver Media Center).hi sud98, can you play the 3d iso files without any audio sync problem?
I am using it and it gives me a good result.
I am also planning to build a HTPC with XBMC. There are motherboards coming with the processor. Will they be good to use them with a graphics card. For example Gigabyte E350n Any thoughts on them.
I use the e350 for audio. If you decide to get one with integrated cpu also go for onboard wifi. These mobos have just one slot either pci or pcie.
G0bble.
Team,
How much does it usually cost to make a decent HTPC?
I'm confused on going for NAS or HTPC.
Vinod
Team,
Vinod
