connect my Sony dvd htib to pc. help me
kaptan
chennai
Hi, please anybody help me. I have a Sony davdz290k htib. I want to connect this to my pc for audio. I have normal audio out jack from my pc. Help me with this techies here.
What inputs are present in the HTIB? If it has a stereo (3.5mm) jack for input then you can connect the speaker out of the pc to it. If it has RCA input then you will need a RCA to 3.5mm converter to connect to pc.
eBay
You can also use a sound card with optical or co-axial output and connect it to the optical/co-axial input of the HTIB.
Check whether the front 3.5mm is for headphone or not. If it is for headphone then you can't connect pc speaker out put to it.
Then you can connect the speaker or headphone out of the pc to this. However you won't get true surround sound. For this you will need to use optical or co-axial connection from pc to htib.
buy a SPDIF header for PC, buy a optical or coaxial cable, connect the header on the motherboard pins, connect SPDIF header of PC to sony with the cable. This the "only" way you will get true surround.
I think the best possible with this is to give stereo input form pc to htib and select prologic processing in htib to have some effect. nothing else is possible.
