mayanks_098
Hi all
I am in a bit of a tricky situation wrt to my current audio setup. Like many of you, I ordered Echo Dot. Problem is I cant figure out a way to connect it to my speakers- Swans M200mkII. Swans are connected to my PC using a Asus Xonar STX card. There is no aux input on Swans. I have tried searching for splitters/ connectors but havent had any luck. I searched the forum couple of weeks back thinking surely there would be people here with the same problem but no luck and hence no solution so far.
So do you guys have any suggestions? What I want is Swans to be connected to both my PC (via Xonar card output) and to Echo Dot (via 3.5mm aux output) at the same time. I intend to use it for Echo dot music playback when PC is not in use. Is there any splitter/ connector which can accomplish this?
