sam9s
- Joined
- Aug 25, 2009
- Messages
- 5,239
- Points
- 113
Thanks for the link Sam. Do you oknow if it supports DTS-HD-MA and Dolby True-HD passthrough? E350N does that smoothly.
Edit: Got the answer.
This NUC does NOT support DTS-HD in a Windows environment. The Intel specs clearly list DTS-HD as a supported audio format but Intel is refusing to release the correct driver stating that the NUC does not support DTS-HD. DTS-HD does work with OpenELEC installed. So the hardware does support it but there is no proper driver for Windows.
Thats seems strange, NUC passes through both DTS HD and DD THD on OpenELEC and this is my personal experience. I assembled an NUC for my friend and installed OpenELEC, and all passthrough worked just fine.
Coming to windows environment I cannot vouch as I did not try it, but it makes me hard to believe that windows would not support DTS HD passthrough on NUC
