Dali Ikon6 auditioned
varma_vikas
delhi
Hi Dr. Bass,
Today I auditioned Dali ikon 6 dali zensor
Zensor was paired with Yamaha and ikon6 was matched with Denon amplifier.
Dali ikon 6- 90,000
Zensor--40,000
Both the combinations were average and nothing was special. Denon with Ikon 6 was little more open sounding.
I found my woodstock is far better in detail, clarity, bass, low volume sound, specially if I compare the price. Dali ikon6 with denon would cost approx 1.30 k.
I cant understand either I am looking for some extraordinary product OR manufacturers have started providing highly AVERAGE, ORDINARY products in extraordinary prices.
Yamaha with Dali Zensor was atleast acceptable( however below average in my terms).
If this is the way for quality products it means a good audio system will cost approx 10 lakhs to somebody.
Dr. Bass, when I asked about DYNAUDIO with dealer he showed that he has listened to a new name in audio world and gave the expression like he is not aware with name.
Then he told me that the kind of product I want for me, could only be auditioned in Mumbai, not in delhi. He told me to go to mumbai for good quality products.
The Ikon 6 is a really good speaker. I don't know which Denon amp was used but I think it probably wasn't enough to drive the Ikons. You need a sure footed amp to get the most out of them but this depends on your budget.
The Zensor should have been easier to drive. Did you try the Denon with the Zensors? I would imagine that would have given you an idea about the amp + speaker combination.
+1
this is probably the first post I have come across that said the Icon 6 is not good. Either the OP heard some other speaker, or quite likely the amp just didnt have enough juice in it to drive em. It could even be issue of seriously messed up acoustics
Icon 6 is a terrific pair of speakers. Price has shot up. When I was looking last year it was like 65K or 70K after bargain
I remember when I heard PSB T6 it didnt sound that great. It was paired with a NAD. (Although NAD's are pretty good, I believe that particular amp wasnt enough) I was advised to try pairing with a different amp. I went back and auditioned with a more powerful Denon amp. The T6 came home soon.
Even if the amplifier would be different, how much difference would have come?Could that be 100% different. Only some %. Bass was totally lacking. I had raised the bass to full. No punch felt.
ikon 6 is an excellent speaker.... it does require good amplification. and it is not for huge-bass lovers... although it produces a very good quality accurate, fast and lean bass.
I am sorry to say however it is not the reality. Just I can say it is average speaker
I don't understand why a good speaker should need a sure footed amp to get the most out of them? If a speaker is good then its good no matter what amp is used to drive them and if its bad then its bad irrespective of the amp used to drive them. Then how come with the same amplifiers other speakers are able to perform well.
I believe that any speaker that requires more power to drive it uses too much of compensation in their cross-over for balancing the anomalies in the drivers and enclosures. This causes it to suck too much power from the amplifier and the power transfer between the amp and the speaker is not good enough. Such speakers usually have unbalanced impedance curves and need high damping factors amplifiers which are very expensive ones. An example of this is the Thiel Audio speakers. They use extensive compensation network in their cross-over which prevents any typical amplifier to drive them effectively. More the number of passive components (read capacitors & inductors) you use in the cross-over network more the energy storage and release issues with them causing ripple, decay and ringing effect. A capacitor stores charge and release them during the decay cycle also causing phase shift. Similar is the effect by using inductors causing energy release and phase shift.
This could be one of the reason the Dali Ikon6 is would not suitable for a typical stereo amplifiers though i have not heard them, but am going with your comment.
Right,
This is exactly what I think Hari ji,
May be I have heard a lot better sound than this dali ikon.
I had purchased woodstock aw602 in 2004 and when i am out for new hunt since then, I found that woodstock is still far ahead than these crap audio systems.Only the prices have been increased. Qualities have been getting low.
For eg- Paradigm studio60, earlier rates were 1.10 lakhs approx with 7 inch drivers.
Now--1.35 lakhs with 5.5 inch drivers.WHY? This is only & only money making. Nothing else.
People who are appreciating dali ikon , I think have not heard the quality sound ever, otherwise they would have not said this.
Vikas dali is NOT for anyone looking for huge volume of bass. It produces tight but lean quantities of bass, required only to augment the mids. It is not suitable for rock and metal, but for midrange rich music.. jazz, classical, slow rock, vocals etc. Also denon is not known for quality stereo amps. Dali would sound better with marantz, arcam fmj series, or similarly neutral amplifiers.
For your tastes.. audition monitor audio rx6 paired with marantz, b&w with bryston, rotel or if possible classe, epos m series with arcam or musical fidelity, kef q700 with marantz/mf, dynaudio with some high current amp like naim or bryston.
Hi Thirthankar,
Thank you for your reply,
First of all sorry for being rude about the audiophiles who said good to Dali,
Actually I am very frustrated.
First I auditioned Paradigm studio100 with rotel 1550 and that became the horrible experince.
TOTAL HARSH SOUND, JUST LIKE DEFECTIVE PRODUCTS.
No way they were sounding like 1.90 lakh of speakers. I straight away thought that--" is this the product for which people pay 1.9 lakh rupes".
If this the product then I am far better with my woodstock I had purchased in 2004 for 40,000 rs(speakers, amplifier, equalizer).
U can easily understand in just one week day, somebody try to take out the time to audition something and found that either people are not aware themseves(dealers), or products are not good OR are over priced like b&w speakers OR are not available for Demo.
Whatever we people are doing, doing on the basis of our own knowledge,whether I am taking whole lot of time in writing to you people OR ruining my weekly off for the audition, but dealers are just making the profit and selling crap products .
LOT OF DEALERS(MOST OF ALL) DO NOT KEEP GOOD PRODUCTS JUST BECAUSE GOOD PRODUCTS DOES NOT CARRY HUGE MARGINS FOR THEM.
THEY KEEP THOSE PRDUCTS IN SHOWROOM WHICH CAN PROVIDE MARGIN TO THEM.
NO KNOWLEDGE, NO GOOD SUGGESTION, NO GOOD PRODUCTS THEY HAVE IN SHOWROOMS FOR DEMO NOTHING.
I FOUND ONLY ONE PERSON WHO IS NOT ONLY A DEALER BUT PASSIONATE ABOUT MUSIC TOO. THAT IS DANNY IN BASS AND TERBLE GURGAON.
Today when i auditioned dali , i asked him about DYNAUDIO and dealer started giving different face expression like i am asking about an ordinary product or he just listened to a new name in audio world which does not have any speciality.
DYNAUDIO is already recommended to me by many people in this forum.
have you been to NAD showroom in Lajpat Nagar. Ashish, owner of the showroom, is also an enthusiast.
I would suggest you to listen to some PSB speakers, specially their BS, and give your comments.
Hi Thirthankar,
The tendency and culture in India is that if any product is priced high then its supposed to be good no matter what its quality is. That's a kind of physco-acoustics that even Bose plays quite well. Take an example of an average Indian who goes to buy say a pair of shirt or trousers. I am sure 99% of Indians do not understand about the quality of the cloth, tailoring and current fashion trend. They then only go by the brand and the price tag to judge the quality of the shirt or the trousers. If they have paid over Rs.2000/- for a shirt of a branded company no matter how lousy the shirt, design and the pattern is and they later make others believe that its the 'IN' thing and is current fashion and the best shirt to wear in the world and will go on to tell its softness, how it smells and what feeling it gives him. No offences there he is trying to justify the monies he has paid for that exotic brand and will not take any argument, and you should also not try to win an argument in this case, else you risk loosing a good friend in him, as his ego is getting hurt.
Apply this analogy in other areas too and you will find similar experiences. Hence brands are very important for people who do not understand the technical aspect of the product nor do not have to time or interest to understand the technical aspect of the product. Take an example of myself - i do not understand anything about photography or a camera nor do i have the technical capability or interest to understand them. Then i do not have any choice but to stay with a branded product like NIKON or may be SONY. Other competitive products say OLYMPUS may be 100 times better in feature and quality for the same price tag, but i do not know about that and due to my own laziness for getting the required details before purchasing. Hence brands have been and will always continue to be a major integral part of business in India no matter even if they sell crap product for the price. But who cares, by then BRANDS have already sold to the customer and the customer is proud to own an exotic brand no matter what's its quality.
My two cents.
I used to have the same feeling. But now I have seen the light. All it takes is, doing some actual listening (compared to reading online) with good amps. I can share two experiences that changed this perception for me.
First one was when I bought Sennheiser HD 650. Due to work situations (lots of travel), not wanting to invest in full sized gear, I turned to portable audio. My first impression of Sennheiser HD 650 was that they were crap. They sounded worse than all my other headphones (ranging between 30-300 USD). I was so annoyed I actually put them on sale. Not that I didn't try to make it work. I bought 2-3 amps trying to get the most out of them including the highly acclaimed Little Dot. Nothing made it sing. Since I didn't get a good offer soon enough, I bought a FiiO in the meantime. FiiO turned everything on its head. Sennheiser HD 650 was the worst 500 USD I invested in my life, a decision I regretted every single hour I tried to make it work, looking for the "audiophile" sound it was acclaimed for. It was nowhere to be found, UNTIL, the FiiO came to rescue. FiiO turned HD 650 from a mediocre overrated expensive phone into a stunning performer. It was an entirely different headphone for me now. That broke the myth for me, that "an amplifier is just an amplifier" and that "any good speaker must sound good regardless of the amp used to feed it".
FiiO wasn't the only one example I have had. Having had success unlocking the potential of HD 650, I decided to experiment more and went ahead an ordered a NuForce Icon HDP. What a revelation. Right when I thought now HD 650 was singing, and there wasn't much left to see what these phones could do, I was proven wrong again. NuForce Icon HDP took HD 650 to an entirely new level.
Where was the magic? I had to ask myself! Was it the DAC? No, it wasn't. I was already feeding it some very high quality DACs. The difference I was hearing were the difference being made by the amp in the FiiO and the NuForce. The myth, that the "amp makes no difference" and "any good speaker ought to sound good regardless of the amp" was broken forever.
HD 650 wasn't the only one example. The same happened with my bookshelf speakers.
When I bought my bookshelves (a vintage speaker), they were being played with a Denon amp. They sounded good and I bought them. After having spent weeks at home, as I went ahead doing critical listening, I started to notice the imperfections. And I knew it had to be the amp I was using with them, because where I listened to it, it sounded utterly transparent and musical. So I sold the Onkyo AVR I was playing it with and bought a Yamaha stereo amp. Things improved but still not there. I sold the Yamaha and bought another Onkyo stereo. This Onkyo was a vintage amp made in 80s and was supposed to be a very very good amp and was everything the conventional "audiophile wisdom" said an amp should be. It was a very high specification made in Japan kit. Hefty power supply, ultrawide frequency response, very low distortion, high damping factor, a beast weighing 16 kg net.
After buying this amp, I thought I was giving "enough" to these speakers. But it wasn't enough yet. These speakers didn't start singing until I fed them with two entirely different amps. One of them was a Denon AVR and the other a SET amp delivering 25 wpc. Surprisingly, the sound was the best with the 25 wpc tube amp. The myth that a good speaker is a good speaker and amp makes no difference was broken yet again.
Many speakers just need to be matched. The match doesn't need to be a match of numbers, like a large number of people do, such as so and so speaker needs so and so many watts of amplification. So and so speaker are so and so Ohms so need to be driven by so and so amp. These numbers are purely indicative and say nothing about how an amp will match with a speaker.
Most likely reason, matching! Or, the speakers are genius. Buy them immediately. If I could come across a good sounding speaker who are not fussy about matching I will buy them instantly. Unfortunately, most good speakers need to be matched with appropriate electronics.
Sir, I humbly request you to go out and audition Dali Ikon. It is not right to comment on things you haven't heard.
Dali Ikon 6 were the best speakers under INR 1 lac, when I bought them and I had heard "nearly everything" that was available at that time in Delhi under 1 lac. Nothing, absolutely nothing, came close to the Dalis in terms of transparency, fast transients, neutral frequency curves and sheer musicality. The only speakers that came close to them were DynAudio and they were more expensive.
And please hear them with good electronics, not some entry level junk. Dalis are very revealing (GIGO), so hear them with appropriate electronics. Otherwise you hear imperfections of the amp, not the speakers. I have heard them with Primare, McCormick and McIntosh amps. Whereas McCormick and McIntosh were a bit of overkill, I do think the minimum they deserved to be matched with was Primare. I felt the best matching of Dali Ikon 6 was Primare CD30 and amp I31. These components complemented each other not only in terms of musical abilities, but also the price.
It is obvious that yours is the rant of a frustrated music lover, who is unable to find good knowledgeable people who can demo you some stuff they know about. Things will change for you once you meet some people who know the stuff they are talking about. The sheer fact that the people who you have met have been "giving different face expression", says a lot about your experience. Meet the right people and your perception will change.
Read my post no #14 above. That may open your eyes. Dali Ikon were the best speakers available in India under 1 lac till a few years ago. Things may have changed now, but still they are a great pair of speakers that never fail to impress.
I never said that an amp is not an important gear in the audio chain. But its not practical to swap amplifiers just because its not able to drive your speakers. The vice versa is also true. If you are going to do either then it becomes a very expensive hobby / passion where you will have to spend a fortune to get a good sound signature.
I have not mentioned about the Ikon6 incapability to deliver good sound with a normal amplifier. I have not even seen the Ikon 6 let alone hear them. The one who have already heard the Ikon 6 have commented about the amps requirement. I will not want to audition Ikon 6 with any high-end gear either. Even if i judge Dali Ikon 6 it will be only with my humble Sony TA-AX44 stereo amplifier only. If it passes that then its a good speaker else not. Reason being i cannot upgrade my amplifier to fulfill the Ikon 6 requirement. There is always a limit till where you can go with upgrades and the sky is also not the limit. If you are ready to spend lacs of money then its a different issue. More over what's good sound and what's not is very relative and personal.
I would also be interested to know how other speakers sound with the same amplifier that are used to drive the Ikon 6. Do they sound equal or better than the Ikon 6 as this speaker already have a requirement for a demanding amplifier.
^^ My point is, if someone pays for a speaker like the Dali ikon 6 or similar, then shouldn't they give it the food it requires?
What is the use of buying an Arabian mare, feeding it cr@p and then saying that the mare is not worth the price.
And if a speaker sounds good with one amplifier and another sounds bad, that just doesnt mean that the one sounding bad is a worse speaker, It just needs something else. power is just a part of it. I think speaker-amplifier synergy is more than just power.
The hunt for the perfect sound IS about hunting for synergy, which means studying the equipments to determine what it needs, trying it out, swapping it with something else if it doesnt do the job.. and it goes on. That is why it is normally recommended to decide on a speaker which suits the musical taste of an individual most, and then hunt for the perfect electronics to accompany it. And that means not only the amplifier, but the source, the dac, even analog interconnects.
But how far one is willing to go is just determined by how far he is willing to go for the sake of audio. It is not also about spending tonnes of money. One can spend comparatively less and still end up with a perfectly good system provided he does the hard work. For some people it is not worth it, they settle for a compromise after a time as they have things which have higher priorities for them. And that is perfectly normal and acceptable.
But its not acceptable to call something crap because it is not allowed to perform upto its ability, or because it is asked to do something other than what it is meant to do.
There was once a post, where someone wanted to pair an B&W 804D with an Onkyo receiver. Now are you telling me if the speaker does not perform well in this case it is the speakers fault?
Hi Dr. Bass,
Dali ikon 6- 90,000
Zensor--40,000
What amplifier model was the denon which was connected to the ikon 6
Well I'm not surprised, most Denon amplifiers readily on display at stores use cheap class ab amplification with cheap low quality parts.
Class ab amplifiers tend to do better on lower quality speakers by giving the illusion of clarity through artificial brightness.
The ikon 6 is a bright speaker, when you pair it with a bright amplifier, the result will be very poor.
That is what you experienced first hand.
Well, obviously, you've been listening to it for almost a decade. Your neural pathways have evolved to receive sonic detail through that tonality. What did you expect?
Refer to my comment above.
You don't know what you're looking for. Anything you're saying beyond this point is just rambling.
You need to first understand what you're looking for in your mind. What your mind wants. Because if you don't, everything else will sound like crap and you will call it crap.
Yamaha with Dali Zensor was atleast acceptable( however below average in my terms). If this is the way for quality products it means a good audio system will cost approx 10 lakhs to somebody.
10 Lakhs to somebody, 10 hours of education to others.
What is this Dr.Bass reference you're consistently using, if you wanted to talk to Dr.Bass you should have pm'ed him instead of making this post public.
Right,
Define what is better sound for us please.
Big words, for someone who hasn't even written down what type of sound he prefers and calls everything else crap.
Companies change, competitions change, management changes, cost of production changes, the world is not a static place.
Also bigger driver cones mean nothing without knowing whats behind them.
Ever heard of the word preference? People have different preferences, choices make things interesting. I would hate to live in a world with just one choice of music because I for one sure know I've gone through 3 different sound quality preference changes.
Amplifier makes 100% difference and so does an open mind.
Do you even know what frequency that bass knob changes? 30hz? 60hz? 120hz? 240hz?
And as for punch, larger driver does not equate to punch and neither does a punch mean it's bass.
Punch is measured by the amount of air displaced by a woofer. This equates to the speed of the driver. The speed of a driver is measured by it's waterfall plot diagram. Two 5" drivers which has an excursion equal to one 10" driver will generate the same amount of punch but this is not bass either.
Bass is low frequencies. And the lower you go, the less you hear. You go down to 20hz and your clothes will flutter without any sound or punch, THAT is true low frequency. It's not something you hear at all below 20hz.
You're calling everything crap without even educating yourself or asking people.
The rest of the world thinks otherwise.
Hi Thirthankar,
Did you even check what type of amplification it was? Class a or class ab or class b?
What's harsh to you may be clarity to others.
If it's their preference, yes it is.
If you don't know what kind of sound you prefer or can't define it, then yes you are indeed better off sticking to the woodstock setup which your neural pathways have evolved around.
I'm not trying to attack you but honestly, the only person who seems oblivious and unaware here is you.
Being an audiophile isn't window shopping.
It's a journey of self reflection through educating oneself and understanding one's preferences and finding a setup that appeals to that self reflected understanding to find a sonic quality that best appeals to us.
When we reach that pinnacle of understanding which pleases our minds, we will achieve it by hook or by crook and nothing can stop you from getting your hands on it.
It took me 2 years to understand that I like the sound of Pre-klipsch Jamo configurations and I went through 3 different phases and dozens of auditions till I reached this conclusion. When I came to that realization I searched online for 1 year to find the speaker model that I wanted until I finally found it.
You consider auditions a ruining of your holiday??
If you have to rely on someone else's passion to justify your own, you need to rethink your priorities. Passion is a reflection of self understanding.
Which dealer? where? when? Also there are hundreds of thousands of brands, why are you even expecting a dealer to know every brand?
I don't..why?
Because you have not done any real research or any self reflection. Understand yourself before you try to understand anything else.
Everything is within one's reach, it's just a matter of how much priority you want to assign to it. If you know what you want, you can even find a 2,00,000 inr pair of speakers for 30,000 inr.
