destructor
Hello All,
I am shifting to new place in few weeks and planning to install a home theater, which would give a decent sound output - Would need your suggestions/ advice on the same:
Let me give some details about the dimension of the room and electronic items to be placed:
150 sq feet area (10x15)
TV to be placed on the closer side of the wall i.e. 10 feet width
Samsung LED TV 5 series
Videocon D2H - HD
My queries:
Currently electrician has made the provision for speaker wires but those are low quality ones, which are available at the electrician shop. I have read across forum that wire also plays an important role in good quality music:
Or will the current wire be fine to attach to the speakers?
if not, What should be the gauge of wire? 16 gauge should be enough for my room to get a good music or it should be 14 gauge?
How much length wire would I require? and where should I buy it from and any specific brand?
Which brand music system should I opt for ?
My budget is between 10k-25k?
I did my search and found below on snapdeal. How is this? any other brand in this budget
Yamaha YHT-196 Hometheater Package - Buy Online @ Rs.23910/- | Snapdeal
I have seen some tower speakers in this budget at croma and ezone, how are those ones?
I play music/ movies through TV from my pen drive. I don't ever use cd's. Will it really require Blue ray player to play it for good music output?
Answers to above question would help me do setup for my other room.
Thanks in Advance!!!
Videocon D2H - HD
My queries:
