abhijeet309
Also check Tannoy Mercury V4 FS they will cost around 30K, they are gr8 value for money.....and u can use your old speakers as surrounds and replace them in future.....
I seem to be getting no replies
I have one more question.. how good are the klipsh F-10 when paired with denon and where can i audition\buy the klipsh speakers in bangalore. Also if anyone knows can tell me its approximate pricing...
Thanks and please reply..![]()
AVR + Power Stereo Amplifier?
Are they both different kind of products?
Sorry I'm new to all this as well.
Abhi, did you check Denon 1913?
Denon 1612 has Sub woofer Pre outs...which is usually found on all receivers... What i meant was Line level Pre outs for all 7.1 channels so that you can add power amplifier later...
Marantz most of the current models are generally good for for both Music & Movies..Marantz SR 5xxx/6xxx series If you specifically ask...
For other brands, you can look @ wharfedale diamond 9.x/10.x series Affordable after Sonodyne... A Top of the line FS 10.7 will set you by 64K.. they have FS range from 40 - 65K... A center channel speaker alone will set you by 15K....
Then you have PSB speakers..Image T5/T6 FS speakers.. Around 55/75K resp... Not heard the price of PSB Image Center channel speaker...
Polk RTI series...Again a bunch of FS to choose from ranging from 40K - 60K...Center channel again 15 K..
Any international brand largest BS speaker range starts from a minimum of 20K..So if you are planning for a FS, then multiply the BS speaker price by approx 2 - 2.5 times...You will get an approx price.
If you search the forum with a specific speaker model, you will get the latest prices & contact details in that thread....
Try audition as many speakers as you can for your budget....Then you can pick which you liked/sounds best to you...
I actually auditioned Polk tsi 400 with denon 1612 yesterday at Profx and i was blown away, especially when I asked the technician to turn off the psw 125 subwoofer and i hardly noticed a difference..I was offered this combo at a price of 52000.. How good a value is Tannoy now and how does this compare to the polk tsi.. Any place i can audition this in bangalore?
Pro FX guy set this demo up for me last week. You really have to play with the AVR settings and different audio tracks to judge the Tsi. Good value buy under 30 K, and good build quality but you should only expect sound quality and performance for an entry level FS only. Base response is very poor with out PSW. Even the PSW adds an artificial base only. Mid range is bright even with Denon.
Ok.. i will then have one more round of audition and listen more carefully..
Can you tell me which one you would suggest in and around the same price..?
I auditioned the Tannoy mercury v4 at ht store today and I must say its awesome! I am given a quote of 32 for v4 and 26 for 1612 I still hv bargaining to do as the main owner was not there.. now looking into the future considering I buy v4 which center and subwoofer will go with this best? Also what could be the best price for v4(any current or previous owners view appreciated) please do suggest..![]()
Polk CS10 is good center, u can go with Mercury VC too.....about subwoofer u can go for roar 210, velodyne impact 10, polk psw 110, warf 150.....
Polk Tsi series has a very different acoustic signature than mercury v4, not sure will go together well (no audition experience with this combo). Velodyne impact 10 is entry level from velodyne. Personally I liked the entry level sub from paradigm. Psw 110 will be my last option for a sub
many many congratulation....
one question while you auditioned...was the 1612 was powerful enough to drive the tannoy mercury V4 floorstanders......
thank you mate for information
Have any of our friends heard the Klipsch F-10 tower speakers. Are they good for around 150 sq.ft. for movies as well as music? In which category do they fall i.e. bright or warm. Can we discount the Sub-woofer when playing these towers.
Will it be good to pair them with Denon 1612.
