Denon AVR speaker channel reconfiguration challenge
Anands123
Hi, looking for some guidance here. My 3 year old Denon AVR 4700H is producing a cracking sound from the ‘height1’ channel and it affects my front height speakers. I am trying to see if it can output the same signal on height 2 channel instead as it is free and hopefully not damaged. I can’t seem to do that as the various amp assign settings force me to use height 1 by default unless I have 4 height speakers, even in that case the height 1 will be in play for one pair and still introduce noise.
I have tried to verify that height 1 channel by changing speakers and cables but the issue seems to be in the channel itself.
Any suggestions appreciated.
Are you sure it's the AVR and not the speaker ? Would be good to swap the left height and right height speaker cables & see if distortion is swapped.
Looking at the manual, there doesn't seem to be a way to assign a single pair of height speakers to Height 2 on your AVR. If getting it repaired isn't a possibility, you're left with having to disconnect your heights and run the Denon's Speaker Virtualizer DSP for height effects.
Thanks. Unfortunately that seems to be the case.
Yes I tried that the distortion travels with the speaker post.
Related to this scenario, is there any solution other than to get it repaired? Am gathering that the repair might be expensive as the motherboard might need to be changed.
