theraindew
They informed that the X 2000 cannot play digital files from Zone 2. It can only be played from Main Zone.
Zone 2 by itself cannot play USB files but it can play radio or any other analog signals.
After more testing today, I can confirm what was told to you above is false. My Main Zone is OFF and I can play songs directly from Zone 2. However, the display on Zone 2 shows only volume +- changes. But all other buttons, i.e previous/next/mute still work, but just wont show up in the display.
If you have a TV connected though, its pretty straight forward as playing through Main Zone. You should be able to see the display and just work off Zone 2. Since you do not have a TV, try to keep only files (songs) and no folders in the USB drive (for checking, easier as zero navigation). Connect it and switch on Zone 2 with Main Zone off and just press Enter on the remote. It should play the file.
