@ Sumanta
I do not have the skills to design a tapered TL line and all my designs in TL has been straight line. Also i do not follow the classic TL design approach where the driver is tuned to the resonance freq. I tune it much higher than resonance. This keeps my line shorter but thicker due to increased cross-section area. Also there need not be any off-set required in this design.
If you have the 12 FRX driver, i would suggest you the measure the Fs, Qts and Vas of the drivers before I design and publish as in my experience the published and measured values vary from 5% to 15% depending totally on your luck. I will post one design based on the published parameters for the discussion today for the 12 FRX.
A quick calculation gave me the following dimensions with the published parameters for the 12 FRX
H = 36", W = 21", D = 21". Cross-section area = 390 sq.inches. Terminus preferably at the bottom - hence needs stands for escape of LF. Tuned at 80Hz.
Will need to add 7KG of polyfill stuffing for the odd harmonics with damping coefficient of 1.89 pounds/cubic feet.
Since Vas of this driver is very high (105 Liters) it will give too high, punchy and deep bass which could shake everything in the room. Recommended for outdoor use or may be OB loading.
Superb Hari!
Thank you so much!
Now other can use these dimensions and make their own big boy TL speakers. thanks again.
As you already know I go more with my ears than with measurements and I do not own measurement instruments either.
There is another driver of Ahuja which is a 12 incher and having double power handling capability. I think that will be even better performer.
I will make a TL if such a situation comes in future.
I have a special liking on Ahujas you know
Hi, sorry to highjack the thread, but i have a similar requirement.
I'm using a pair of philips HiQ speakers in an open back (not sure if this is the right term - It's a stock Sony Cabinet with a perforated back covered using some sort of felt)
the sound quality is amazing, but there is nothing below 100 Hz. I'm not planning to squeeze anything out of it using any TL or eq, but rather, try to build a woofer that can take care of the lows (<100 hz)
Looking for cheap high sensitivity woofer, I came across the Pioneer TS W304R & the ahuja L12 MB200. What sort of enclosure would be advisable? I was interested in something like an H baffle, but due to space constraints, I would need to keep them pretty close to a wall, plus am not sure how/where to design an H baffle.
a vented box is the backup plan (both drivers have recommended vented box plans) but any advice on choice & design for an open enclosure would be appreciated
Thanks!
If you can not place your speaker(s) 3' away from the front (listener's) wall, then even your mid and high will not give you the required imaging, rest assured the lows too.
If you can, then you probably can make a Ripole (folded baffle) design that I am happy with. It is compact (that is one of the key reason for my selection of this design. You can also choose to use a combination of slot loaded open baffle design and Ripole design which I feel is even better to have best of both designs. Means, having the benefit of decreased value of Fs of driver as well as increased SPL on the front end of the driver.
Make sure SPL of the low frequency driver is around 10dB higher than the mid & high drivers reproduction level SPL.
