As much as I've been reading up on the subject of diffusion vs. absorption, I really don't quite get when we should use diffusion, and when we should use absorption.
What I could gather (I could be wrong, and I'd love comments on this) is that:
1) Smaller listening spaces benefit better from absorbers.
2) Diffusers should generally be used only on the middle of the wall behind the speakers, or on the wall behind the listeners.
3) Diffusers are best avoided in smaller listening spaces. If the gap between the listener's head and the front/rear wall is less than 3.5 meters (or 11 ft.), diffusers are best avoided.
4) Diffusers are best avoided on the side walls. For the side walls, absorbers are best, and these should be used to tame the first and secondary reflection points.
5) Too much absorption tends to deaden the room. Diffusion when used properly, can keep the room "live" enough.
Are these conclusions of mine correct? I'm most confused about the use of diffusers.
The reason I got to thinking about all this, is that my 40" TV is right between my speakers, just about a 16" behind the front baffles of the speakers. The speakers are 6ft apart. I've always suspected that the TV was messing with the staging & imaging quite bit, and that I could get a sharper and wider soundstage behind the speakers if I could remove the TV, or fix the reflections from the TV. Somebody who had a listen at my place last week commented on this right away. We covered the TV with a large thick towel and we both felt that it improved things.
1. Removing the TV is unfortunately not an option. So, I have to fix the reflections. To do this, I was planning to paste some eggshell foam, or foam with a vertical slat design on some light panel (foamboard maybe), and then lean the contraption against the TV. The TV is about 8 ft. from my head when I'm in the listening position.
Now the question is, do I use foam (absorbers), or something designed as a diffuser for this? I'm tending towards going with absorption here, but would diffusion be better?
2. A second doubt I have is this: The baffles of the speakers are about 3 ft away from the front wall (the wall I face when I'm listening) and they are about 7 ft away from my head. If I were to use something on the front walls behind the speakers, when should I be using?: absorbers or diffusers?
Do let me know what you folks think!
