Digital Stabilizers - Horrors in our Apartment
Sinewave inverter with enough load capacity and equipment.
Wall mains -> Stabilizer - > Equipment.
Dont mix inverters , stabilizers and surge protectors.
I got your point of not mixing stab and surge protector.
However I have inverter for entire home and now my query is:
What about
main -- > surge protector --> equipment (when there is power)
main will switched to inverter -- > surge protector --> equipment (when there is no power)
What about
Appreciate experts response on this... thnx..
I'm using this method. Mains > UPS > surge protector. So when there is mains it is like Mains > surge protector. I use the surge protector as an extension board to connect all my devices and there isn't any problem so far. Most UPSs have built-in surge and lightning protector.
Thanks Baijuxavior.
Do we need a stabilizer when we already have built-in. I heard we should not have multiple stab in chain. Can someone please enlighten on this?
Stabilizer is not required if there is no voltage fluctuation.
Agreed but difficult to make decision as I can't wait for equipment stop working to know there are fluctuation issues.
Apart from that my question is still open?
We have seen now a days tv/refrigerator comes with some built-in stab and will it be wise to have one more stab or it would be harmful or wastage having multiple stab in chain?
You can use stabilizer in the order mains > stab > inverter > devices. But the stabilizer should be of a higher VA to support the inverter+devices. I'm using a 5KVA servo stab > 1.2KVA ups > surge protector > devices. I am using the surge protector in the chain as an extension board purpose. Do not connect inverter > stab.
hello ram
i am new to ht set up and has less info about connections and all so pls provide valueble info thanks
i ve yamaha r675-sony blu ray player-f f12 sub-power ( all 3 us power based 110v120v ) -power bright 3000vc step down transformer
and tv either plasma or led (tv is not baught yet looking for)
power supply condition : weekly once twice power cuts(not for long time ) sometimes
more depending season
flatuations rarely
which servo stablizer is best for this
what else i need for set up other than this as i want to use multiple us devices from one 110v out on transformer which powerstrip shud i use for multiple device
even i heard about converter powerstrip dont know wheter i need one or not
thanks !
For those who want a quick response to a sustained voltage rise ( a surge) , a relay ( or better, a regular power 'contactor' ) will take typically 20 mS or so to operate. ( That is about one cycle of the mains voltage ). This also depends on the delay in the trigger circuitry ! In most cases this should be OK for our electronic equipment. The relay or contactor will switch out ( off) the power line. Power contactors have superior contacts and current carrying capacity than ordinary relays.
To get faster operation one could use a solid state relay, but it is probably not really required. It would also be a more complex and more expensive solution.
You also don't want the mains to be cut off if there are only a few cycles of raised voltage.
The 'spike busters' are only meant to clamp transient voltages on the power line to a safer level and are of very short duration ( under 2 mS usually ). This will not help with usual mains voltage fluctuations which is the power line voltage going up or down at a relatively slower rate.
Good ( fast reacting ) servo stabilisers can be quite effective if the voltage is within it's operating range. Beyond that it would need to cut off. But if the mains jumps from 230 V to 300 V suddenly a quick acting cut out might be required .
You might need to keep some lighting circuits working even if all the other critical equipment is shut off. Shouldn't be difficult to make a few emergency lights ( using LED's ) that can handle 300 Vmains. That way you wouldn't be suddenly plunged into darkness !
Many stabilisers do have a high voltage cutout. So they would automatically take care of the refrigerator and / or other devices connected to it. I would use something separate to protect the music system and the TV rather than use just one device at the mains to protect everything in the house.
