Beginner_N
You mean a cabinet for Hypex?Can you do a Puriti class D build?
Would love our Indian DIYers build for either Hypex/Puriti builds.
Please refer to the design in attached pictures
DD pre amp module only @ Rs.3200/- in 2020, present cost don't know.How much one DD preamp costs? I want to try one in my system. Any help in this regard is appreciated.
I need this complete board , only power amplifier ..... Low power version ...Thanks Shailesh for your detailed review. This is a killer amp/preamp combo.
I actually requested Aniket to design a hi quality amp which should be easy to build and economical. He has done an excellent job on this combo. The Power amp can be configured into 75W or 120W per channel. It has onboard power supply and protection circuit. The user only has to connect a transformer, minimum soldering requires as it comes as fully soldered board, including PCB mounted heatsinks. The Preamp is very good too and can be use as headphone amp as well.
Here are few builds and reviews on Lencoheaven https://www.lencoheaven.net/forum/index.php?topic=30648.0
I am posting few pics of PCBs and modules
Amp Pcbs
Preamp PCB
Power amp modules
Preamp Modules
Sachin
Oh ok. No problem. Hopefully someone will put up their kit for saleHi
Sorry, no kits available with me.
Sachin
Where do I get this amplifier board
Can I get your contact numberThis amp will work happily with as low as 20V DC, but I will recommend to use a 18V, 200VA transformer, you will get around 25W with this, which I think is sufficient for efficient drivers.
Hi, Can I get your contact number?One more DD preamp and Power amp completed and delivered.
