Hi, so I've posted pics on Reddit but got no worthwhile reply:
I have access to the Amp and need to repair the following (assuming it needs such a thing):
1. 1-Speaker - looks to be some issue internal to the case: what's the back of the speaker made off because I'll have to drill and cut it away from the hardwood case? (what wood was used)
2. VU meters light up but the needles don't jump about.
3. Sound on both channels is emitted only in 'A+B' mode by connecting one speaker to the 'Right' port of each channel. I can't run two speakers on the same Channel (A or B). The 'Left' port seems to be broken.
I have 0 experience fixing this/audio stuff BUT I do have some limited experience with multimeters, oscilloscopes and transistors. I still need a circuit diagram to poke around.
The amp is working somewhat (I can hook up my Philips speaker and get sound) and I am familiar with Bangalore/SP Road for parts.
Can I get any help from this forum in this regard (fixing the amp. circuit diagram) What's the amp worth in as-is condition? What if it was repaired - how much then? [I'll need to invest in tools: drill and some kind of jigsaw to cut along the glue line?] Any reading list for amps. Anyone from Bangalore? (just to be clear - this is a world class CRAPPY amp - the components are similar to what I see in old Indian V-Guard stabilizers and such but it's Indian so )
I don't know what Cosmic Speakers I have - the sticker is missing (tiny narrow rectangle). The upper sticker with COSMIC is there.
I'll try to post clear pics - assuming I get a reply
