Diodes are still in PO, BTW local parts are
For each set -
Rs 385 all local parts
Rs 225 all PCB pins and rubber sleeves for wire terminals
Rs 150 postage and packing
Rs 760 Sub Total-1
Tomorrow I will add Semiconductor import price (Approx Rs ~5000 for 24 diode+ matched Quad MOSFETs w/ previous ref of customs duty). I will start courier them from day after tomorrow. Anybody need details please drop me PM. In next couple of days I would be starting my build too.
Hi Capt,@ OMishra, I'm confused
Are these in addition to the components sourced by Sachin?
I think he posted by mistake for local parts
What all comprise the local parts?
Further update. All part are in hand. Now I received all parts including remaining diodes from USA. So now I will coordinate with Sachin and send these to Sachin as he prepares final checklist of parts and send it to everybody.
You already got all items including those diodes from first batch expects few from me. And it's late, your parcel is already packaged for Sanpada office.please hold my consignment, as I am leaving day after tomorrow for a long vacation :yahoo: and will inform you when I return,
Thanks .
and what are they used for?PCB pins and tabs are optional.
Guys,
Question for om.
I see .22 ohm (16 nos ) resistors 3w. I suppose these go on the power supply boards. I see the markings on the power supply boards as .47 ohm. Can you please confirm the changes.
Pandu
Hi Pandu,
Please use .22 ohm resisters in place of .47 ohms on power supply filter board.
Sachin
om/Sachin,
I know that electrolytic capacitors, input jfets, output mosfets, diodes need to be soldered in with proper polarity signs. I also found that film capacitors dont have polarities.
Can you list out any other items where polarities need to be checked for.
ALso I was trying to measure .22 ohm resistors resistance on my DMM. It was showing inaccurate values. When researched on teh net I found out that low resistances cannot be measured accurately.
Do we need measure resistance across every item before we insert it into the PCB boards.
For first timers everything is big. Please bear with us for some of these NOOB questions.
Pandu
It would be difficult to answer these questions. You need to look at the complete kit and the parts and then you will be able to figure out a lot of things from your background of DIY. If there are any questions further, you can address them here. I am saying this because I have built this kit and it is very easily laid out and easy to understand.
My intention of posing that question is to figure out whether I would need it or not and if needed, to get all the components in one shot rather than asking for them in piece meal which is more taxing to Sachin & Om.
