Captain, hope this helps you.and what are they used for?
http://www.hifivision.com/diy/28245-diy-pass-f5-turbo-v2-initiated-29.html#post422344
You can solder wires directly on PCB but its better to use connectors.
You can see few pics here http://www.hifivision.com/diy/28245-diy-pass-f5-turbo-v2-initiated-26.html
No problem! As you wish. I would request sachin to take out those from your packet.Thank you Sachin & Om. I'll take Sachin's suggestion and would solder directly on to the PCB.
Didn't Sachin say exactly the opposite, Capt.?
Captain! Please don't take below as marketing gimmick.Since he said they can be soldered directly on to the PCB, I'm of the opinion that by soldering the wires directly, I'd be reducing one additional joint for smoother flow of electrons in the circuit.
As per my understanding, the downside would be: Running the risk of damaging the track on the PCB if one has to desolder and resolder a few times which I reckon would not happen in my case. Hope I'm correct in my assumptions here.
Its okay for signal wires to solder on PCB e.g. input leads from RCA sockets. But for PS and speaker wire - these pins and terminal will allow you good contact and 2.5 sq mm wires too. Otherwise in order to fit into 1mm PCB hole you will end up with thin wires. Also assembling after fitting PCB will be easy with terminals in wires. Imagine you are fitting everything inside chassis and then trying to wire them together. In case of multi strand wires there is risk of shorting loose strands inside box.
Thanks Om,I am thankful to FM sann who found his contact. This person has following heatsink manufactured with tapped and finished to our PCB design.
Om,
How is your amp build coming up.
I Have been held up with personal commitments. Going slow.
Need to get back to stuffing the components on the power supply boards next.
Pandu
The heatsink is ready, anodized and holes for PCB and cabinet are tapped.
Dims 300 x 150 x 83 (24kg / meter)
Sann
Thanks Anil,
What bias value should we look at, for these heatsinks?
Regards, sann
@Anilva. Will these be fine for the basic Pass 5.
@Sann. If anilva gives a nod. I may be interested in a pair too. Want to finish my build too.
