Hi Friends,
I spend a lot of time to complete my Amp, Printing PCBs, Itching, Drilling, Component Assembly.... & then Finally Testing, It Took almost 5 Months to get it working Properly. In between I did went through a lot of Problems during testing, There was some fireworks too.. Burning of Resisters, Transistors, My Testing Speakers etc... I also stated a thread http://www.hifivision.com/diy/62274-help-needed-sort-out-problem-crescendo-me-amplifier.htmlto sort out some Problems which i faced during testing of this Amp. And i am thankful to our Fellow Member "Shaan" he guided me in Proper direction to sort out the Problems.
I have been running this Amp for More than like 20 Days in my testing Enclosure for observation, its working Fine, No humms, no Hiss just Pure Sound. So now its time to Shift this Amp in a Proper Enclosure which is built by myself.
The Enclosure will be made from Heat sinks (Left & Right), Top & Bottom will be M.S plate of 1 mm thickness & Front & Back will be Acrylic.
Below is the Photo of Heat Sink on which Both PCB's ( AMp & Protection) will be Mounted (Drilling & Tapping Done)
Amplifier PCB Fitted.
Assembly of Unfinished Enclosure "Just wanna see how will it look after Completion"
After Drilling work is completed both the Top & Bottom plates will be going for Power Coating. Back Panel of this enclosure is yet to be made, because i am still thinking on which side I should place the Input RCA & Output Connectors of Speakers, Should i fit them like..... Right input (Single RCA) & Speaker Connector on Right Side & Vice Versa. or Should i Place them Together on any one Side. I am unable to decide it.
Sadik
Sadik
