krishtrinity
Finally some honest review of how pointless is buying an expensive DAC
https://www.youtube.com/watch?v=xBlADcpbxbg
https://www.youtube.com/watch?v=xBlADcpbxbg[/url]
I haven't been through the video (just replying the title) but this is true until you buy, own and live with it for some time .
I am responding just to warn potential enthusiasts not get misguided .
Higher cost does not necessarily mean higher performance. It may simply mean increased reliability and wider operating ranges.
So reviews are good/bad/ugly depending on what you are looking for.
Raghu
I would also like to hear from some one who has really put his effort to select a true hi-fidelity audio component purely based on the objective tests and not through the regular subjective listening method.
The cost / benefit assessment of a dac completely depends on your setup and audio priorities.
You cannot see a pin head if you have an elephant blocking your view. The elephant can be in the attitude as well as in the setup. It also depends upon the value of the pin-head to you. In audio, the magic usually starts with the pin-heads.
If DACs sound differently, then it can only mean one thing, one of them is introducing something additional to the mix or one of the DACs is not really doing the job right. That is the only 3 points the guy is making, and if one takes a step back and looks at it, he does make sense indeed.
You cannot have 2 DACs sounding different, and then both of them doing the digital to analog conversion process 100% perfect or even right. One of them has to be missing the mark or introducing something extra into the mix.
This is getting interesting [emoji4]And which component is supposed to change the signal in the chain?
All pre, power, IC and speaker must (not should) sound same because -
1. Pre only attenuate signal amplitude, must not add or remove anything.
2. Power should only amplify the amplitude of the signal, must not add or remove anything.
3. Interconnects should only transfer the signal, must not add or remove anything.
4. Speaker should only transfer electrical signal to the exact signal that has been fed to the microphone in studio .... not to say, must not add or remove anything.
So, all the speaker, amp, pre and of course, by all virtue, a DAC must sound exactly same!
From JBL Control 1 to B&W 802 D3
From Topping t20 to Symphonic Line
et al
But the thing is not like that, BTW.
