gopichandpai
6,666/- for only 11 HD channels and extra charges for more HD channels makes hathway HD expensive isn't it?
They are going to add another 4 HD channel very soon. since Rs.6,666/-package comprise of 11 HD channel... out 4 channel, 2 might be NGC and Discovery and dunno about the other two... Going forward they have plans to add more number of HD channels with reasonable charges.
Qualtiy of the SD channel has significantly improved and the channel count remains the same...
In hyd too channel listing has changed and the up gradation message appeared.However the channel count remains the same
If we calculate 2000 as hd box cost then cost comes to 4666 / 12=389 per month which includes all sd channels plus hd channels also. Not bad if u compare largest sd pack of any dth provider.
Hyderabad Update:
HD is now active in HYD. The yearly subscription charges are Rs.6,666/-.
May be true. But hathway is known for not having stocks of digital set top boxes. Same might happen with HD boxes as well.
@petes, @canchi,
Are they taking back old digital set top box when you opt for HD? How much discount are they giving if you return the old set top box?
Hyd HD List
1. History
2. M tunes
3. Travel xp
4. utv stars
5 colors HD
6.Cnbc prime
7.Movies Now
8. Luxe tv
For this list, not worth to pay that much!!!
Will consider only if all the promised channels are delivered!
@petes, @canchi,
Hyd HD List
1. History
2. M tunes
3. Travel xp
4. utv stars
5 colors HD
6.Cnbc prime
7.Movies Now
8. Luxe tv
