tusharshukla1991
Do check Yamaha AVR, I think it is better for movie and music.
I am into music as well so shall I go for Polk S15 / BA A25 as Fronts or will T15 be okay?
Go for surround setup only if you can properly place your surround speakers. Otherwise its better going with a 2 channel setup.Hello All
This is my first post.
I am going to setup a HT and I read a lot of posts from this forum. My budget is quite limited so I wanna use it smartly (max 50k).
I have a couple of questions that I am sure I'll find a answer to
1. Which is better budget receiver with good speakers or vice versa
2. Should I go for smart receivers (wifi etc) or buy a andriod box.
I was thinking to go with polk TL1600 and a budget receiver like pioneer 531 or yamaha 3067.
Other option marantz 1508 with yamaha 5,1 speaker package (expensive reciever n cheap speakers)
Also, please let me know a decent android box, my primary use is youtube, prime and 1tb HDD for movies.
Room size: 9*13 (tv on 13feet wall, 43inch lg FHD)
I live in an apartment so clarity is more important than high sound.
For matching setup can I settle for: polk T15(front) | Polk T30(centre) | polk T15(surrounds) | Taga SW90/Yamaha SW315??
I have one completely different question, I tried to search in the forum but couldn't find a proper answer....
I have Swans 2.0 setup which I am currently using for music and after buying 5.1 setup I'll send the swans to my brother. But he wants a 2.1 setup as these speakers don't have enough bass for movies.
Is there a way to connect an active subwoofer (like yamaha or polk) to the active speakers?? Otherwise I need to buy him logitech z623 (and they don't sound good)
Marantz and Denon are manufactured in the same facility. Marantz is tuned more musical relatively speaking however Denon is no slouch either. If you are able to audition then nothing better than that. Otherwise either would be a good choice.Hello @marsilians
Yes thats the plan now... I was going for Denon x540bt with boston a26 but now I can see that marantz 1508 is back in stock for 34k on hifimart!
On comparision I think marantz is better then denon in terms of features (wifi etc) but power rating is 50rms/chnl while denon is 90w.
also, confused between boston a26 vs warfedale 220
