Help : How to connect Vu 55 4K + Tatasky HD + Sony BD home theater
sankar_17
chennai
Can any one please help me on to connect home theatre + Vu 4K TV + Tatasky HD STB.
TV has 4 HDMI , 2 with HDMI 1.0 and 2 HDMI 2.0
I think an ideal setup would be as follows.
Tatasky HD STB ----- HDMI 2.0 -----> Vu 4K TV
Sony BD home theater ----- HDMI 2.0 -----> Vu 4K TV
Tatasky HD STB ----- Digital Optical Out -----> Sony BD home theater
By doing this you can njoy TataSky audio though SONY HT too :yahoo:. Just make sure to select the correct source in Sony HT & dont forget to min the TV volume.
I have a diff setup with my Tatasky HD, Onkyo AV and Panasonic Plasma
TataSky HD --> HDMI --> Onkyo HDMI (In:CBL/SAT)
Onkyo HDMI (Out) --> HDMI --> Plasma
This way I play TV volume (via HDMI passthru) and when I want to play sound via AV, then I just switch on the Onkyo and select the correct Input (CBL/SAT).
This does not need an Optical cable and only one HDMI to my TV.
Hope this helps too !
Which Hometheater is it? What are its INs and OUTs?
Do you have any digital Out from the TV? If yes, that could save you additional wiring. If not, then the the network suggested by @apbinu is perfect.
