Just like others I am also planning to buy an decent home theatre. My budget is around 40k or can stretch it up a little more.
Something about the desired system which going to rock my place:
- Usage: 60% for music and 40% for movies
- It should be capable to play all types of songs such as rock, jazz, classical.
I was thinking about some system after lil search here and over the internet, they are as follows:
HTiB
Denon 391
Denon 591
Yamaha YHT-292
Yamaha YHT-392
One of my friend has suggested
Marantz 3053 AVR + Pinnacle's speaker's package with 200w sub. Its coming near about Rs53000.
Can I expect a good home theatre system in my budget?
What you would suggest, should I go for HTiB or buying an sepertae AVR and seperate speakers package would be good to build the good system?
Thanks in advance
HTiB
Denon 391
Denon 591
Yamaha YHT-292
Yamaha YHT-392
Thanks in advance
