Help!! Speakers for Norge 2060
AbhiShek.
Jalandhar
Recently I bought a Norge 2060 Amplifier.
Now I want to purchase a set of speakers for it for home use.
I want a decent bass and treble from them.
My budget is around 10k-15k.
The speakers i'm using are from 90's and does not produce soothing music.
Please suggest
I'm a newbie, Don't know much about technicals of audio but want to listen very good music. Please feel free to suggest :confused:
I think you can consider the Q Acoustics 2010/2010i or Wharfedale Diamond 210/10.1 speakers from Hifimart that are available at your budget or slightly above. Check below link.
Bookshelf/Monitor - HiFiMart
If you do not mind Indian brands, then you can try the Krypton audio speakers designed by our forum member Hari Iyer. Thanks to MLTL speaker design, they should be sounding pretty good.
Krypton Audio - 3-1/2" Full-Range Bookshelf Speaker - Pair
Warfedale diamond series bookshelf speakers would better go with norge and shall suffice your requirements.
