Hi there!
After reading the reviews through the various threads, finally, took the plunge for my first hifi seperate system .
After listening to limited setups(due to non availability of choices and brands locally), I have purchased a CA 340A SE demo piece for the amp and Tannoy Mercury V1 bookshelf speakers and the Marantz CD5004 for the source and set up the system. Wasn't sure if the combo of CA and Marantz would be fine. It's a risk I have taken to combine Marantz and CA overshooting my budget . The sound quality is very nice, crisp and clear. However the sound is forward and light/bright and a bit lean and forward - not to my liking. I am looking for a slightly deeper/warmer/sweeter sound. I am thinking the weak link is the amp - CA 340A SE and want to change it. Would NAD 326BEE/316 BEE or Maranzt PM 5004 be better companion to the Marantz CD 5004? Should I change the CD player to CA 350C/550C? Or should I wait for a few days of playing allowing the speakers and CD player some burn time? Any suggestion/feedback would be appreciated.
I listen to wide genres of music - Rock, Metal, Blues/Jazz, Country, Old Bollywood/Ghazal music etc.
Thanks in advance!!
.After listening to limited setups(due to non availability of choices and brands locally), I have purchased a CA 340A SE demo piece for the amp and Tannoy Mercury V1 bookshelf speakers and the Marantz CD5004 for the source and set up the system. Wasn't sure if the combo of CA and Marantz would be fine. It's a risk I have taken to combine Marantz and CA overshooting my budget
 . The sound quality is very nice, crisp and clear. However the sound is forward and light/bright and a bit lean and forward - not to my liking. I am looking for a slightly deeper/warmer/sweeter sound. I am thinking the weak link is the amp - CA 340A SE and want to change it. Would NAD 326BEE/316 BEE or Maranzt PM 5004 be better companion to the Marantz CD 5004? Should I change the CD player to CA 350C/550C? Or should I wait for a few days of playing allowing the speakers and CD player some burn time? Any suggestion/feedback would be appreciated.I listen to wide genres of music - Rock, Metal, Blues/Jazz, Country, Old Bollywood/Ghazal music etc.
Thanks in advance!!
