I am going to San Fransisco next week, and will be visiting Los Angeles as well. Can anybody guide me about good hifi stores where I can audition different amplifiers. Also are there any good stores who deal in used gear. I am looking for an amplifier for my Tannoy GM15.
Hi anshul... It would be easier to buy source gear in the US and lug it back. It won't be difficult finding a quality step down transformer for it in India, that will function quitely.
Amps are heavy and monstrous to carry. Besides the good ones will be really power hungry. And you will need a big high quality step down to run it in India. And the big ones hum like crazy.
While iam an advocate of running 110v gear with a step down, as the step down provides an additional degree of protection. But amps are a no-no, and a completely different ball game altogether. So better stick to low power consumption items like streamers or dac's.
Also please bear in mind, that the max weight of any peice of baggage cannot exceed 31kgs as per airline rules. So if you buy something heavy, then you might have to buy a case to just carry it back. And not to forget our friendly customs guys once back here
If my memory serves me right, on the usaudiomart.com site, in the advanced search feature, you should be able to select 220v there. That might make short listing gear easier. And if you buy from this site, please check with the seller about shipping. As many sellers only ship to the address registered with the PayPal account. So might have to get a local friend to pay and receive the item. However if you can meet, pay and collect directly from seller, in person. Then it will be safer.
All the best
... And happy hunting
Edit :
1. Parasound gear is usually dual voltage compatible.
2. Usually class D gear is dual voltage compatible. Nad, devialet etc.. Have to check about peachtree though.
3. Aurender and innuos can be voltage swapped internally by you.
4. Auralic and lumin gear cannot be converted to 220v last time I checked. But please recheck again.
