Hiraga Le Monstre build on the anvil
Any other feedback on PCBs?
Sorry Forgot to mention about the PCB's... Yes there is one suggestion. In your next Project i would request you to make the Pads bigger for resistors, & capacitors. These PCBs were made for DIYer's & there are many new comers too in our field, those small pads makes difficult to solder for a new DIYer. The kits which i received were already soldered and the soldering was very poor one of the reason may be because of small pad size. I had to re solder many pads to make them proper.
Sadik
Sadik
Yes, that I have taken care of it in later projects. I have created my own components and library's. It has minimum 2.5-3mm pad sizes.
Thank you for your suggestion.
And another thing i would like to know is the Biasing, how much biasing is required for these transistors... Right now the transistors are biased at 780 to 800mA each.
OMishra, welcome back after a long time!!
Thank you, quad.
Trying to catch up things slowly. It will take some time for sure.
Yes transistors can be biased upto 1.5A with 12V-14V supply rail, subject to heatsink cooling. Currently they are in middle somewhere 700-800mA approximately. But making power rail to 14V is sufficient.
