HK AVR 70 HKTS 5 vs HK AVR 70 JBL CINEMA 300
Prateep
Delhi
I would like to know which one is best in sound and quality:
I am staying in rented house, Room size: 3mtX3mt
Room may change due to staying in rented house. So I would like to keep range little bit higher also.
I have choosed below models:
1) HK AVR 70 HKTS 5
2) HK AVR 70 JBL CINEMA 300
My 1st question is:
Budget: 50k (AVR + Speaker)
1) How many Power (in watts) is recommended for above room size.
2) Which one is better sound for music/movies
3) I want to connect tatasky (std box) to AVR to upscale to 1080p.
I am a fan of HK/JBL. So i don't want to buy any other brand.
If any other model (AVR/Speakers) is good please suggest me!
Hi you can check for Denon or yamaha or Onkyo AVR's which are good enough..
I think 3x3m room size 60 to 70 watts per channel is more than enough ..however since u r telling u will shift in future ..(if that is the case u can go for min. 100W per channel)
