Have you heard about polarity of Power Cable?
Well yes, this is Electricity 101. But it usually is irrelevant in practice if one uses the supplied and perfectly adequate power cord and plugs in into the mains socket.
If using a two pin plug the simplest way to see if it matters is to insert the plug into the socket the other way aroundI will show you how to find out the polarity of power cables.
Wait for an hours please.
If using a two pin plug the simplest way to see if it matters is to insert the plug into the socket the other way around. In a few rare cases, the sound quality improves - or deteriorates badly in one position - often it doesn't make any difference.
PS: I am not an engineer, so I would be happy to understand why in some cases this happens - and also why in many cases it doesn't make any difference.
	I want to know in their relation with "Husband & Wife", is it compatible to add 2 active TL subs for stereo listening?
I use two TL subs + satellites with an AVR for stereo listening..
Can you share a pic of your rig?
HiFi: Asus Xonar STX > JRiver > Nad 2240PE > AR2ax Speakers
	@elangoas: The two subs Taga SW 10 V.2 look like they have been laid down and made ceiling firing![]()
Plz excuse the poor quality of mobile pic in low light..The subs are in the front corners of the room..
Subwoofer -Taga Harmony platinum SW 10 v2
Satellite - Sonodyne Avant LCR 250..
AVR -Denon x3300..
Husband & Wife with 2 children![]()
Actually 2 subs are better than one to create accurate bass extensions and also nullify boominess. Unfortunately in most setups, it becomes impractical due to space and cost consideration. Lots of info on the net about the benefits.
In the above pic, it would be interesting to see if bass response improved if the subs we're isolated with rubber feet.
linkie said:As valuable as these subwoofer placement strategies are, they do not by any stretch eliminate the need for bass trapping in a room. This point cannot be emphasized enough. All rooms have a multitude of bass problems apart from modal issues
Could you please help me understand. Are you suggesting that room boom issues could be nullified by having two multiple subs ?
gik linkie
@elangoas: Cannot make out from your pic. Do you have any bass trapping or treatment in your room ?
ciao
gr
This was discussed a while back on drkrack thread - http://www.hifivision.com/av-enhanc...oom-acoustics-diy-ready-use-9.html#post720479
Nope.. Yet to.. But sooner..
I must have missed it. where ?
I've had the pleasure of several listening sessions at his place and definitely do not recollect him using two subs to defeat his room - he had room treatment in place.
It will make a rather big difference to your listening pleasure when you do. If you are chasing tuneful bass, hurry !
ciao
gr
Most common placement of subs are one on top of each other or equidistant from the center channel. I have felt the effects of these 2 configs.
A third one which I have personally not seen is to put them in a 'L' formation, eg., one sub behind center channel and second one perpendicular to it midway on either right or left wall.
Lots of discussion on this in usual places eg., avsforum etc.
