Neatly wall-fixed plastic cable trays running on both side walls of the room. Instead of the trays running on top, take it near the floor level, then go vertically up at the point of location of the surround speakers.
Half-inch thick plastic cable trays would be fine. They are usually in white colour, and if you are that particular, you can later paint (emulsion wall paint) them with the same shade as your wall.
