Inverter vs servo stabilizer
For home use, servo stabs are good enough if there are huge fluctuations for household equipment. For sensitive equipments is here you need an online ups to avoid damage and cleaner power.
Does online UPS provides 'cleaner' power? I have read in many places that it is not and not good for audio devices. It confuses me...
The more expensive online ups definitely give pure sine wave as well as provides separation from distortion and harmonics. The cheaper ones I am not too sure. The expensive ones include apc and Emerson.
I need a stabilzer to use for my home theater system. The technician suggested to go for 3 kv inverter with two 200 Watts battery
So that I will get stabilizer functions and full house power backup. Please clarify this.
Depending on how much you want to spend I'd recommned a full-sine wave double conversion power UPS. It runs completely off battery - A/C charges battery and battery runs your system. Pure, ripple-free A/C goodness. Makes a joke out of *fancy power cables* and also to some extent expensive power conditioners. And by the way I have an older one that I can sell you :-) :-)
Depending on how much you want to spend I'd recommned a full-sine wave double conversion power UPS. It runs completely off battery - A/C charges battery and battery runs your system. Pure, ripple-free A/C goodness. Makes a joke out of *fancy power cables* and also to some extent expensive power conditioners. And by the way I have an older one that I can sell you :) :)
Can you share your contact details?
It sounds like the technician is recommending an inverter with a capacity of 3 kilovolts (kV) and two 200 watt batteries to provide both stabilizing functions for your home theater system and backup power for your entire house.
The batteries would serve as a backup power source in case of a power outage. The capacity of the batteries, in this case 200 watts each, refers to the amount of power they can store. The technician is recommending two batteries to ensure enough backup power for your entire house.
It's important to note that the sizing of the inverter and batteries should be determined based on your specific power needs. You can read the article and find the most suitable for you https://www.propaneva.com/best-inverter-generator/ . The technician may have made this recommendation based on the power requirements of your home theater system and the size of your house, but it's always a good idea to confirm that the system will meet your needs.
