JBL cinema 300 + Denon 1312
pavz!
bangalore
HI All,
I am new to this forum. :)
I was planning to buy a new home theatre, kindly suggest if below combo would go well as match. my budget is around 40k-50k.
JBL cinema 300 and Denon 1312 AVR.
With that money you can get much better combo. For starters I would suggest you to visit a few HT stores and audition the HTIB packages and SUB sat systems in your budget.Below are few stores where you can listen to some systems.
htstore.in
profx.com
cinebels.in
audioplanet
vector systems
Modern world
Denon 1312 is a good entry level receiver. You can demo some good 5.1 speaker systems to go along with the 1312. Some of them are:
Wharfedale Moviestar DX1
Wharfedale Moviestar MS100
Wharfedale Vardus 300 5.1 package
Polk Audio RM705
Polk Audio RM6750
Polk Audio Blackstone TL1600
Boston Acoustics Soundware XS 5.1
Boston Acoustics A2310
Jamo A101 HCS
Jamo A102 HCS 3
JAmo A102 HCS 6
Jamo A200 5.1
Jamo A320 HCS 6
These are some of the systems you can demo and then decide what sounds the best.
@rohitpuri, you can go for Yamaha 373 as it's the newest entry level AVR. Also you can consider Denon 1512. But first of all you have to declare your budget.
@rohitpuri, you can go for Yamaha 373 as it's the newest entry level AVR. Also you can consider Denon 1513. But first of all you have to declare your budget.
Thanks bpranay
Budget 40-45 K
Getting JBL 300 - 20 K (It has got a 150 w active sub)
Yamaha 3064 (371) - 20 K
Do u think that Denon 1513 will pair better with JBL ?
My usage will be mostly movies 80 % and music 20%
Space does not allow for floor standers
If preference is movies then you can consider denon 1513 as Yamahas have little edge over music than movies. And with 80% pref to the movies, you are likely to get better SQ with Denon. I can not comment on JBL package as I never had an audition before with JBL. But if 45K is your budget then you can even consider Boston Acoustics Soundware XS 5.1 which is available at 24K (you can get some reduction after negotiations) which would be good with both 371 and 1513 as per your budget.
I today went to reliance, amdience mall and they did not have Yamaha 371/3 or denon 1312/1513.
Went to studio 4 -
Did not have JBL 300
Heard JBL 200.5 speakers and Harman AVR 70
Liked it but he was quoting 45,000 total which i thought was on the higher side and i have not heard about the avr very much
Anybody out there who can throw some light on AVR 70
Stay away from Harmon Kardon AVRs. They don't have much support in India and they are not very reliable. Go to Delhi, Audition Denon AVR + Boston acoustics Soundware XS.
You can contact the following stores :
NEW DELHI
Home Audio:
M/s. Audio Video Operation (AVO)
Contact No: 098183 80493
E mail: [email protected]
Dealers in: DENON, Polk Audio, KEF, QED & JM Lab
M/s. Bass N Treble
Contact No: 011 45509308 / 09999016124
Dealers in: Denon, Polk Audio, Kef, JM Lab & QED
M/s. Hi fi Zone
Contact No: 011 23863304 / 098112 56782
Dealers in: DENON & Polk Audio
M/s. Purple Wave Infocom Pvt Ltd
Contact person: Mr. Manoj Singh
Contact No: 011 64584749 / 50 / 098102 98631
Email: [email protected]
Dealers in: Home Products
M/s Sight & Sound India
Contact No: 093110 09238
Dealers in: DENON
M/s. Sound of Music
Contact No: 011 655 15557 to 55561 / 098100 50300
Dealers in: DENON
M/s. Trinity Sound & Vision
Contact No: 011 4506 4321 / 098106 10306
Dealers in: DENON, Polk Audio & QED
