LG OLED B6 is here! And...
This is a clean setup that i wanted to implement.
Tata Sky > Denon x1300 > OLED B6 ARC
I am, however, facing issues with the HDMI passthrough. I have a blank screen when the x1300 is on standby and TS and TV powered on.
The image pops up on the screen after i switch on the AVR. If i then switch off the AVR, the screen goes blank for a brief moment before the passthrough takes effect and the TS STB image continues. How do i get the passthrough to work without having to switch on the AVR?
Slightly confused. Are you saying that no image comes when your receiver is in stand by mode? Did you check what input the pass through is set to? You should have Auto, last Input or a selected input.
MaSh
MaSh
I've selected the input (DTH / STB) for passthrough. The passthrough doesnt work when the AVR is on standby. However, it works once i power cycle the AVR (turn it on and then turn it off).
If i select a different input on the TV (say USB), and then return to AVR input, the passthrough doesnt seem to work any more. I have to powercycle the AVR again to get the passthrough to work.
Ahhh OK. Hmm that is weird. Maybe someone else with the same model can confirm whether that is the default configuration.
MaSh
