allajunaki
3) you can play mkv files using your PC/laptop. even my four year old PC plays them well. using DVI/HDMI converter you can connect it to your TV. you will get decent quality. I use a WDTV for the same. in my experience it gives better PQ.
WDTV will give you better convenience, or more cost effective (if you are building a PC from the scratch for this purpose).
Agreed, with the default Divx codec + TV wont take you far, but there exists some very High Quality open source decoders, that can do some amazing post processing. You are only limited by how much ur PC can take.
I have been using ffdshow for last couple of years, and I can tell you that no standalone player can come close to the magic that these codecs deliver.
The downside of this codec is the learning curve with it (But if anyone is willing to give it a shot, Im willing to help em out
 ). ffdshow tryouts | Official Website
If you transport video via HDMI (DVI <-> HDMI converters will not incur any loss of PQ, since HDMI carries DVI signals for video anyways) at native resolution, then all the scaling you do off the image can be entirely in software. This gives some of the best upscaler algorithms available, along with some of the best postprocessing of images.
The obvious downside of this way will be the convinience aspect, where you have to hookup cables, do some right click menu action to get everything playing nicely.
