- Joined
- Sep 23, 2007
- Messages
- 3,650
- Points
- 0
4 k IS RATHER VERY VERY good price . buy if working!
Welcome Ram!!
20 Nakamichi Decks!!!!!!!!
My head is already spinning??????
Would love to hear more from u. Can u please post your views on the Nakamichi Transport vis a vis others about which a debate is already on here.
The 480 series of Naks is an unassuming series of Nakamichis which have to be heard to be believed. Even the so called puny 480 with 2 heads has a beautiful dual capstan transport with the classic mechanism which is in itself a work horse.
It handles tape extremely gently and so causes minimal head wear. This deck will blow most manufacturers 3 head decks out of the ball park in terms of sound quality.
Sourav, your deck isn't recording right because of its age. It perhaps needs competent servicing to the record circuit.
Even the 480Z( with dolby C) and the 482 Z are great decks with the 482 being a 3 head iteration of the 480.
Well, mine is spinning as well as I try to host them in my modest abode. lol.....
Nakamichi made a dual capstan transport thats miles ahead of anything else that anyone ever made. The capstans spin at different speeds( as the capstan diameters are different- and the belt had differential tension on the motor pulley and the supply flywheel) so as to put just enough tension on the tape, that a pressure pad is not required in any dual capstan Nak. There is a lifter fitted to the playback head to lift the cassette's pressure pad out of the way and hold it here until the tape is stopped. There dramatically less head wear and tape handling is most gentle. Moreover, scrape flutter induced by the pressure pad holding the moving tape on the playback head is eliminated, resulting in the "Nakamichi" sound! No other deck comes close in transparency to a 3 head Nak. None. Technics made a joke of cassette decks compared Nakamichi. I can't even start to compare the two. Its plain futile!
I heard someone mentioning plastic parts in a Nak transport and heard them ridicule it. Nam made some parts plastic to eliminate vibration in the transport. More soon if anyone has more queries!
Moreover, the frequency response of these heads were( are) legendary and no other manufacturer compares even close. Some of the rec/pb head decks of Naks have a response of 20-20Khz., almost never achieved by any other maker ever!
