Keeping away from Tubes for now just to try an SS. I've been bugging Jacob to come up with a Gaanam alternative.
I'd love to try an ACA. Correct me if I'm wrong but I assume the J2/F3 etc would be much better albeit at a higher price.
Is the ACA the Nelson Pass AMP CAMP amps, a DIY kit? If so, we run DC 2A3s, and two of my friends bought and built ACA amps, and they both individually sent their Amp Camp Amps to me, to sell for them on eBay.
You would be better off learning how to build GOOD DC amps with 2A3s. A good 2A3 amp in our experience, is only of one design : a two stage DC amp. Even when Nelson talks on the phone to my mentor, Nelson says privately ........" triode tubes are better ". He will not say that in public places I bet.
Jeff
iMO, Try PSE 6AS7G and you will be blown !!! Makes about 5 watts per channel. Bass is most amazing you would have ever heard from an SET. Mine are monoblocks and Pure Class A.
Is PSE " parallel single ended ". If so, you need to know that ANY time you parallel tubes, Finals, it is a compromise. A good single 2A3 that the original poster uses, is superior. If you have to run PSE, you simply have a speaker efficiency problem. Get the speaker correct first..... and good things in hi fi happens .......101 dB does it.
Jeff
I will try and answer it as best as I can. I have heard the Rethms with a variety of tube amps from a 45 to a 2a3 to a 300 to a 845 to a 6c33. A 300 tube is not as agile or quick as a 2a3 which in turn loses out to a 45 tube when it comes to speed and agility. Rethm likes amps which are very agile. Unfortunately a 1.5 watt 45 tube amp for some reason doesn’t work too well with Rethm. The 2a3 which is 3.5 watter works perfect. The 50 tube which is the grandfather of the 45 tube will probably work even better with a Rethm. Similarly there will be speakers which prefer a 300 over a 2a3. The synergy between amp and speaker is more critical. On even higher sensitivity super expensive speakers like Pnoe, the 45 or 46 tube amp work the best. And that’s just a 1.5 watter. A 45 tube amp is different sounding from a 2a3 tube amp which is very different sounding from a 300 tube amp. Each SET tube sounds very very different from each other unlike pentodes where there is a little more similarity.
I'd like to express my opinions on tubes.
In my building experience, the Type 45 is a bust.
An ST 45 tube can
never in a million years ever play the lower registers of a grand piano effectively. It has a
non linear playback in that range. Advanced audiophiles may know this. Read Joe Esmilla's SIMPLE 46 amp blog of 2017, when he experienced his very first 46 at home for 90 days.
jelabs.blogspot.com
or, Thomas Meyer in Germany.
http://vinylsavor.blogspot.com/2016/12/the-46-back-in-black.html
The 46
is better. A single plate 2A3 can be very good, such as a JJ 2A3-40, or EML or the NLA VAIC mesh plate.
A 45 is non linear, due to its cheap
too-thin internal wiring, from the plate's assembly to the tube socket pins. A 45's best use is in vintage radios. It was massed-produced in the day, to be as cheap as possible.
More modern tubes are made better. Type 50s are similar to the 45s, nice highs etc., non-linear bass response. No thanks, been there / built that / done that.
I use 101 dB horns for testing, with ALTEC drivers, 515B and 802D. A more modern-built 2 dollar 6AQ5 or a 10 dollar NOS 6005, will murder many of these tubes people discuss, when evaluated in a
single amp, full-range playback - on a highly-efficient speaker. I love testing tube amps on grand piano playback !!
300B amps, in my opinion, are a mistake. They require DC on their filaments,
and this bucks-out the ultimate in fidelity that you can obtain from a AC operated 2.5 volt 2A3 tube. The real mistake of a 300B amp,
is that the owner did not start the audio journey with a 101 db or higher speaker, so they are
forced to use amps over two Watts, which are clunky - sounding. The 300B amps are by their nature, slightly inferior in terms of the highest possible audio performance.
( Yes, I know, many rooms are small in a densely populated country like INDIA ).
All of this I write and share with is " only in my experience, in my opinion. " My background : I have been listening - to 15 inch ALTEC drivers for 76.8 years now. Have fun in the audio hobby. I do.
Very respectfully submitted to you.
Jeff
