coolraghav
Hello,
I am confused between both. I have four FS Speakers to be given output. One is Q Acoustics 1 series and other is Monitor Audio Bronze and MA center as well.
I am planning to install 2 outdoor speakers (as zone 2) probably Jamo ( https://www.jamo.com/products/i-o-5 ) or Community Pro V2-8 (https://www.communitypro.com/products/vseries/v2-8) with second LFE output which will be provided current as required. Could you guys suggest me any other as well which are easily available in Delhi ? -- Jamo is 50% cheaper.
Confusion is between Marantz SR 5013 and Yamaha A1080, I need power basically, the Denon AVR-2113 i am using currently trips mostly at very loud sound that could also be because of ventilation or maybe wires too but it does heat up which I am planning to resolve this time in the cabinet... by using a fan as well ..please suggest a fan too ?
Marantz is quite cheaper than YAMAHA that is the reason which is pushing me towards it, rest I have no knowledge.
Looking forward to your suggestions!
