Jayant_S
I've been one of the IC agnostics forever. Didn't give the connecting cables a second thought and have been using Amazon Basics ICs all along. I've always thought "A cable is a cable - they're all the same" (don't shoot me!)
Then I started reading this thread amongst the several posts on the merit of various ICs, specifically following what Joshua @jls001 has to say. Reading up on what several knowledgeable FMs have to say about ICs here:
https://www.hifivision.com/threads/the-effect-of-cables-a-sane-debate.59567/
With so much real world feedback on the effect of ICs, I felt like a frog in a well!
I started picking Joshua's brain for a bit about my setup and some noob questions - he was kind and patient.
He suggested Mogami 2803 (expensive) or Klotz MC 5000 as a cheaper alternative from Kiran Sales in Mumbai.
Unfortunately the Klotz cable was not in stock and patience is not one of my virtues
So I bought these three ICs from Ali @magma of Sound Foundations :
Othello digital coaxial cable to connect my CD player to DAC
Zeus Z1 RCA IC to connect DAC to amp or Phono preamp to amp
I ordered two Zeus Z1s and Ali very kindly offered me a new IC he's about to release for the same price. So I got the ARES SilverLine, again DAC to amp or Phono preamp to amp
All three have been connected for about 4 weeks and I swapped the two RCA ICs to compare after 2 weeks running in the turntable and CDP chains respectively.
Here's my feedback on all three ICs. I won't pretend to know the technicalities of each connector. I'm just putting down the evidence my ears gathered.
First off the bat, I have to say I'm now an IC convert! The right connectors make a very noticeable difference to your listening experience and these did so for me in abundance.
All three took about 10 days to settle in before I started to hear the change.
Othello digital coax IC : with this cable replacing a generic coax connector I had from CD digital out to DAC, it felt like cotton plugs had been pulled out of my ears. No exaggeration - this IC is really that good! The highs got clearer, vocals sharper and bass tighter with the right amount of thump. I had been unfair to my CD player all this time calling it dull.
Zeus Z1 vs ARES: The only way I could be fair to both ICs was to compare them in my turntable playback chain, where I do 90% of my music listening. The Zeus is well balanced and doesn't add any coloration to the music. I could hear a higher level of transparency in my music. In contrast, ARES sounded lively and a lot more fun! Adding to the music in a good way - response across the frequency range is just so musical. I'm listening to Tubular Bells on my TT as I write this and getting fresh chills down my spine with the vivid Exorcist imagery. The ARES will stay right where it is right now and the Zeus goes into my CD chain.
Thanks @magma for the great ICs and @jls001 for your patience and guidance!
