ankitbhargava
should I just use PEQ in plugin to tame 30hz and 60-70hz peaks a little? This null between 40-50hz is the biggest challenge I guess.Do you really need the room curve? 60DB is really low
what's going on between 70-80hz is too bad, I will be doing more experiments tomorrow to completely bypass these EQ filters and just deal with peaks at 30hz (a couple of db low because that extra energy at 30 gives a kick which is good..haha and tame 60-70hz, boost 70-80hz by couple of db. Not sure how to deal with the null around 40-50hzI think u can little bit increase the target level around 6 db ( around 64 db ) based on ur graph....Check the predicted curve hugging to the house curve atleast >75% .But however u will end up a null around 80 hz...Here u can boost it in the input around 3db .
