Minor Color bleed on Micromax 50B6000FHD
macho3215
Delhi
I see these colors on a black display from right or left angles on 50B6000FHD. Can anyone else confirm if it is same for them.
You see black screen on turning off blueback and turning off settop box or input signal.
I have read that most led panel's have some level of non uniformity. So, how much is acceptable?
In the big size panels, these non uniformities are more pronounced. Similar thing is seen even in our VU 55 Inch.
Edit: In Low cost big size panels especially...!
Oh. Okay. I hope this is then acceptable. VU claims A+ grade panel.
Marketing Gimmicks.... Btw, the question is, is this acceptable for you or is it disturbing you much when you are watching movies ?
Even my Sony has such issues, but when the back light is at full strength, there is light bleed even in my Tv.
Try lowering the backlight to normal level and check.
Doesn't bother at all under normal viewing. Its actually visible only with black background and when you look real hard...so I guess not a problem. The LED actually is extremely bright. I have left it almost permanently at high power saving and still the brightness is sufficient.
My Micromax 50BD6000 came without the user manual. Can any of you tell me how to get hold of a user manual. I want to know if the mini audio out connector can be connected to an external audio amplifier? TIA
HA, then that's not an issue. Don't use the auto power saving option. Just reduce the backlight strength to what that suits you.
Hey can you post a pic taken from 3 foot distance and 8 foot distance.
As per I know some color bleeds are normal for big and cheap LED panels but the question is does it bothers you while consuming content?
It doesn't bother at all while normal viewing.
