Samuel / Reju
Thanks 4 ur inputs.Can u tell me the cost of these Rti-A7 spaeakers ?
Rti A7: MRP is 54K. You should get it for 48.5K.
Rti A5: MRP is 44K. You should get it for 39.5K.
http://www.profx.com/polk_rti_series.asp
Samuel / Reju
i plan to add a line to my signature that says "advice is good but always audition and trust you senses and wallet before you buy".........
well for speakers (m34/m35)with 90-92db sensitivity (m33 is aorund 89) anything over 25W can drive them well. But then again 2W tube amps are known to drive speakers with 90+dB sensitivity well.
So as long as you like the sound of the m34/m35 and onkyo avr (if you are a lover for 2 channel sound - you will upgrade to 2 channel anyway in the future) - go and buy it man.
Profx - Advanced Audio Solutions
Reju thanks for the price quotes.the cost of these speakers is beyond my reach and budget.even telling wifey abt the cost of these speakers will lead 2 unbelievable consequences @ home let alone buying..
Any way will look out for other less priced models.BTW how are Jamo and Canton as brands?Even Mordaunt Short seems to be a good brand !
Canton? is it a good brand? which speakers r u lukin at? share some links pls
Hi Supra
As per ur wish I checked out the cost of mission center m3C2i speaker from Vijay Sales in Mumbai.It is Rs 7536.00.
I wish to have a pair of M30i to complement my M33i for a probable HT set up. Would you please get me the price for the same from Vijay Sales, if possible ? Thanks in advance. I live in Delhi.
vjc
vjc
Ya sure.Pls give me some time.BTW are these M30i's pair of surround speakers?
Take your time. BTW, I could n't get much info by telephone from Vijay Sales.
Yes they would make rear speakers in the set up, while M3C2i can work as centre.
regards,
vjc
