Recently I got for free from a friend an ancient PC running Win XP on an Intel D945GCL motherboard, and all of 1 GB of memory. I thought it was an opportunity as good as I'd get to try my hands on making a PC as a digital source.
So I started hunting for a good sound card, something with AES/EBU output, as my DAC cum pre-amp has digital coax, optical and AES/EBU. And I wanted to try AES/EBU as I'm already using the digital coax output from my CDP to feed the DAC.
It was surprisingly difficult to get a sound card with AES/EBU I/O, unless one goes to fairly high-priced cards (say > $600). And I was not yet willing to spend on a costly card without proving the concept to my satisfaction.
As luck would have it, I got hold of an RME Hammerfall DSP 9632 sound card on loan. This is a fairly old card (bought some 5+ years back) and, as far as I know, no longer in production. This card has AES/EBU in and out.
So in goes 2 new 2GB RAMs, and a newly made 9-pin D type male to XLR-M breakout cable to connect direct to AES/EBU port of the DAC. I also had the breakout cable for the S/PDIF (digital coax). Installed foobar2000, disabled the on-board sound card from BIOS.
Last night I tried playing .wav and .flac files from an USB external hard disk drive.
I first tried with S/PDIF output as I had wrongly used a female 9 pin D connector instead of a male for the AES breakout. I didn't play from S/PDIF long enough to form a proper and coherent impression. After quickly re-soldering the correct D-type connector, I tried the AES/EBU out.
Initial impressions are good. It sounded more forward compared to the S/PDIF from the same sound card, so I ended moving my listening chair back by almost a feet.
Compared to the Marantz CD6003 as a transport giving S/PDIF output to DAC, I could hear better mids, and the quality of lows improved too, while the bass tightened up and gained a bit of amplitude. Imaging also improved. After an extended listening of almost 2 hours by which time both pre and power had attained proper operating temperatures, a faster attack was discernible along with a more natural decay (especially on cymbals and high hats). I also felt that familiar numbers played with greater urgency. I don't know if that's what one would quantify as better PRaT. This will take some getting used to as the overall speed seems to be a bit faster. I felt the same way when I moved from a Pioneer DD TT to a Thorens TD 160. The Thorens played with more sense of urgency so playing speed seemed to have gone up.
All in all, a worthy proof of concept. It is not as if I did not believe in computer playout - I have seen what Shanti uses and I am a convert ever since. Just that I still had doubts on how I could implement it successfully for myself.
FWIW, I used a Belden 1800 (IIRC model number), 2-core shielded digital cable (roughly 2 m long), Neutrik XLR connector and an old, cheap and garden variety D-type connector for the exercise. The S/PDIF breakout is the original which came with the card.
Some questions: I have seen WASAPI discussed a lot in other foobar related threads. Is it available now for XP? Is there substantial improvement over non-WASAPI or ASIO?
Joshua
Joshua
