Rupam
The level setting that Audyssey chooses is based upon the volume that the mic is "hearing" during the calibration. It is sending the test signal through the sub, and setting the volume level so that the test signal received through the mic is at a reference volume. If you increase the volume on the back of the sub before calibration, Audyssey will decrease the sub volume on the receiver to match that reference volume during calibration, and vice-versa. You can alter the volume at the sub or the receiver after calibration with virtually the same result.
Ideally, you would want to set the volume control on the sub so that the volume on the receiver is close to 0dB after calibration. Then, since it is available via remote control, use the sub volume on the receiver to "tweak" your preference after calibration.
