I have also bought an Endico PARA12TRP. I am researching bits. For my build I need chamfer, round over and flush trim bits.
What is the company name of the bits you used? Any tips , warnings that you might have.
How difficult was it to manage chamfering HDF? I will be chamfering 18mm thickness. Looks like its HDHMR at the moment.
Bits I have sourced from local stores. Brands like Jon Bandari, Bullet, are cheap and don't have much life, but this will do for an occasional wood worker like me.
Chamfering and round over will be easy, just check the bearing is flushed in the bottom end or you will get a slot.
The most difficult part is speaker cutout which you have to do multiple rounds and HDF is pretty hard, you will ruin the bit in a couple of cutouts. Invest in the bottom cleaning bit, the rest of the bits like chamfer, round over, and flush trim cheap ones will do.
If you have a jigsaw it doesn't matter.
Jean
