Need help for a Home theater set up
rahulsinghania
Siliguri
I am planning to set up a dedicated home theater room.
The room size is about 220 sq feet ( 20 ft long and 11 ft broad).
I will have projector in it too.
Please could you guide me which home theater set to take. I am planning to buy :
Amplifier : Denon AVR x2000
Speakers : FOCAL Sib & Co
My concern is my room size also. It has concrete flooring. My budget would be for amp and speakers : 80K-1.3 Lacs.
List out the speakers and AVRs with your chosen combinations and go for audition. Then you will be able to decide the best.
To add to the list, you may consider Wharfedale/Polkaudio speakers and Yamaha/Marantz AMPs as well.
There will not be a problem with Concrete flooring. You can place a good carpet on it to reduce some sound waves penetrating through it.
Siva
Denon x2000 would cost you 52k Alone.. Speakers from focal would be costly .. 80 k to 1.3 k would not be enough.
You got firstly decide weather you want to Opt for fronts floorstanding speakers and the 5.1 set up or
The satellite speakers in the 5.1 set up . Secondly what would you use the speakers for music or movies?
