There is 2 mention - Energy storage and discharge / snubbing01- 07 - 2022.......................... GTOs .............................GTOs...........................GTOs !!!
Remember how the GTO caps we use ( 5 uF at 1200 VDC ) were described by me as " totally defining the leading edge of all audio transients" Totally unbeatable in the Power Supply as a bypass ( me and Boli46 ) and unbeatable as a bypass in a speaker crossover??
Below is a very handy listing, of all the WIMA brand caps, and what their different models DO. ( Thanks, Hari Iyer ).
In that, I spotted just a single mention of a GTO ( GTO MKP ) . Please note how WIMA characterize this cap type's performance.
It is precisely what we all heard !!! This datasheet / application guide , of course, debunk's certain 100% GTO inexperienced people.
I came to using GTOs, by being the first person in the USA to listen to it, try it out, about five years ago. When located inside my amps, and on a crossover, not a thing in this world, can begin to touch it !!
How else, can someone DIY- try to build a higher performing audio amplifier ??? Maybe even - dare we think , ( if direct coupled, two tube stages, ultra low in DCR ), the best sounding there is ??
http://wima.cn/EN/applicguide.htm
Arrogance, nope. Its just the simple truth.
Jeff
Mine eyes have seen the glory of the coming of the Lord;
He is trampling out the vintage where the grapes of wrath are stored;
He hath loosed the fateful lightning of His terrible swift sword;
His truth is marching on.
Glory! Glory! Hallelujah!
This "letter" addresses your ideas and thoughts here with a precise degree of accuracy!SIMPLY IGNORE THEM ........ REALLY GOOD ADVICE !! ......... WELL SAID.
nwwdlw
12:01 AM (4 hours ago)
to me
Thanks for the update. Your work is superb as usual.
Looking at the latest EE arrogant rebuttals on your thread makes me realize they cannot see beyond their trained view. Which is usually narrow. That they cannot seem to take your experience and effort as an exercise in thought, a gift.
One would think instead of arguing on their limited view. They would be experimenting at least to debunk your claims. They are closed based on their expert discipline as an EE. Which qualifies them as knowing more about your work than you do without hearing it. Or, experimenting with your methods????????
Damn arrogant know it alls if you ask me.
That is why I dropped away from the forums. I got Sick of the arrogance.
I hope you ignore them. Teach the ones who will listen.
NW
I’m curious here, do you build audio equipment? and if yes do you listen it? Because you stated that a variety of capacitors will perform the same. They may operate the same but do they sound the same? Not trying to start a fight just curious about what you stated.Just because a capacitor is CAPABLE of handling nano second rise times does not mean it creates them.
While these capacitors will work fine in a baseband audio application, standard foil, even electrolytic caps will perform the same and be a lot smaller and less costly.
Read the numbers on the extended data sheet which was not reference here. A "fast" beat in a song or track is hardly "fast" by electrical standards.
You can't apply what seems a common sense conclusion to complex engineering problems. If electrical engineering, especially the behavior of a capacitor to a complex AC waveform was that simple to understand, it would be taught in late grade school!
Yes to both.I’m curious here, do you build audio equipment? and if yes do you listen it? Because you stated that a variety of capacitors will perform the same. They may operate the same but do they sound the same? Not trying to start a fight just curious about what you stated.
I fully accept the fact that when someone states that they did this or that and, in their opinion, the result was a sonic improvement. That's not the cause of any conflicts. Conflicts arise only when someone declares without any basis that some specific physical mechanism is responsible for the improvement. The use of GTO capacitors is one example. It's one thing for someone to say that the use of GTO capacitors improved the sound that they are hearing, but it's another thing to assert that it's the ultra-high current capability and/or high slew rate of GTO capacitors that is what at is responsible for the sonic improvement. Anther example is the use of tie wraps to bundle shielded coaxial cables. It's one thing for someone to express their epxperience that bundling coaxial cables is detrimental to the sound, but its another thing to assert that the reason is because cable ties disrupt a demonstrably non-existent field around a coaxial cable. The bottom line is that this thread is overloaded with one proclamation after another that blatantly contradicts decade of well investigated, well documented and well established priciples in physics, science and engineering. And that's the crux of the conflicts that exist.Yes to both.
Capacitors can sound different. My point here is that installing a special application RF grade capacitor does not increase the risetimes of musical signals. And also since audio is at the bottom of the EM spectrum, the rise times of signals is quite slow compared to other electronics applications. These ultra fast risetimes are not there to begin with.
It's being implied here that an audio amp needs an extreme slew rate to properly reproduce audio. That's just not true. It still falls under the classic 5x rule.
And interestingly most modern audio amps have a 100khz limit which is perfect. Anything higher, which some exotic amps are, is asking for stability problems. And furthermore a tube amp is hard pressed to even do 100khz because of the output transformer.
I could not disagree with you more,. To reply with what one knows to be the truth, point-to-point or otherwise is a manifestation of strength and coviction. Not reacting to statements that one knows are false is the epitome of weakness and cowardice Which side of the coin are you on?Its said - To reply and justify point-to-point is weakness. Strength is in restraint and not reacting. Again its difficult for weak minded to understand and implement this.
Ok, so you understand the details can explain why they sound different I’d like to know and I’m sure several other here also would like some one to explain this. (Speaking if the gto caps)I fully accept the fact that when someone states that they did this or that and, in their opinion, the result was a sonic improvement. That's not the cause of any conflicts. Conflicts arise only when someone declares without any basis that some specific physical mechanism is responsible for the improvement. The use of GTO capacitors is one example. It's one thing for someone to say that the use of GTO capacitors improved the sound that they are hearing, but it's another thing to assert that it's the ultra-high current capability and/or high slew rate of GTO capacitors that is what at is responsible for the sonic improvement. Anther example is the use of tie wraps to bundle shielded coaxial cables. It's one thing for someone to express their epxperience that bundling coaxial cables is detrimental to the sound, but its another thing to assert that the reason is because cable ties disrupt a demonstrably non-existent field around a coaxial cable. The bottom line is that this thread is overloaded with one proclamation after another that blatantly contradicts decade of well investigated, well documented and well established priciples in physics, science and engineering. And that's the crux of the conflicts that exist.
I agree completely!To reply with what one knows to be the truth, point-to-point or otherwise is a manifestation of strength and coviction. Not reacting to statements that one knows are false is the epitome of weakness and cowardice.
Don't bother with replies from " Armchair Audiophiles". It does not mean anything.Ok, so you understand the details can explain why they sound different I’d like to know and I’m sure several other here also would like some one to explain this. (Speaking if the gto caps)
There is no universal perfection in audio. Listening is very subjective. What is perfect for one need not be perfect for another. Guys posting here think there is nothing better than their design. I think this is being naive and stupid. It might be the perfect sound for the posters but that doesn’t make it universal. Pl stop pushing around that what you’ll design is the best thing that happened since sliced bread. If that was the case there would have been just one amplifier manufacturer in the world.![]()
Drlowmu, as long as you are happy with your designs and what you are hearing, that’s all that matters. The problem comes when you start insisting that speakers have to be a minimum of 100 dB, you should use amps only if 2-5 watts, etc etc. You have put forth your thought. Leave it at that. You can’t keep on bringing it up in every post of yours. Let others decide whats best and what works for them.
