elangoas
Thanks Elangaos. I hope I am in the right Direction.
Yup.. very much.. Wait for some more suggestion on ideal room from other members too..
Nah Nah This will be for the TV in ground floor for general Entertainment. That area will have huge glass wall almost 200 sqft. I am not even looking for HT there
Ok cool..
I have choice to build shutters from outside to full eliminate the light from the window.
Ok.. Metal shutters?.. Dark tint glass window, should cut the light by half... And a dark curtain should subside the remaining.. Just thinking on room aesthetics..
My only concern here is the speaker placement and Acoustics management due to the new French Window I am doing. If hanging from the ceiling is a good option I can do that for the surrounds.
If you are looking for 9.2.6 layout, then i think the speakers are best at ear-level, to distinguish the overheads..
Surrounds are best at ear level, or mounted higher than that depending on preference / convenience in your room..
Otherwise I have to fix the speaker position on the wall first and correspondingly position the door.
For the media room you are looking at, you may have issues only for surr back..As you are planning for a door there.. There, you can position the surrback on the wall above the door and tilt it towards your listening position..
Since rear wall is good for reflections, will glass be okay there or does it need treatment (like panel that slides)
Sorry, i have no experience with room acoustic panel.. Having read some members suggestions, to treat some-part of rear wall is good.. Plz wait for detailed inputs..
Wouldn't 175" diagonal need a large viewing distance. For the primary seating I was thinking around 12' or so from the screen.
Not much.. I watch 100 inch diagonal 16:9 screen from approx 11 feet distance comfortably.. Between 12 ~ 15 feet should be fine.. If you think 175 is large, you can settle for 150.. Bigger screen is better IMO..
How forward will the AT screen come- 2' or 3'.
2 feet at the maximum from front wall is enough..
With this one row (3/4 seats) will be around 14'-15' from the front Wall. Rear wall will be 3' - 4' behind,will this be enough space for speakers. (Additional seating will be bean bags or fold able chairs pulled in/futon).
Most HT set-ups that i have come across have been in the living room .. Can guess from your room size.. Should be just fine..
.I just checked this on a wall. Woah, width will probably be the full room. some specs I got from amazon
Which aspect Ratio is the preferred one for the projectors. My plan is to have lots of kids movies/Telugu Movies/ English. When I am alone I will watch lots of TV Series (netflix or Prime). Live Sports for groups
- 176-inch Diagonal, 2.35:1 Aspect Ratio. View Size: 69.0" H x 162.0" W. Overall Size: 73.6" H x 166.7" W.
- 180-inch Diagonal, 16:9 Aspect Ratio. View Size: 88.3" H x 156.9" W. Overall Size: 92.9" H x 161.6" W x 1.6" D.
- 165-inch Diagonal, 16:9 Aspect Ratio. View Size: 81.0" H x 144.0" W. Overall Size: 85.6" H x 148.5" W x 1.6" D.
16:9 IMO.. Can do both 16:9 fully for all media (youtube, casting from mobile) on 175 inch screen & a 21:9 (for most movies) with black bars on top & bottom..
Coming to the projectors, how good is the screen masking feature in them when playing different ratios.
No idea on that..
Do we get the woven AT screens in India or the perforated ones. I read Woven screens are a very good choice.
You can get perforated ones from theater dealers.. But one FM suggested not to go for perforated and instead look for woven..So i procured spandex lycra from Tiruppur and DIY AT screen, 100 inch diagonal..
This will not be a constraint as I have the spare room and no problem with the Leds distracting. One more thing how do one maintain the speakers behind the AT screen if it is fixed.
Good one .. Other than dusting, i don't think you need to do for maintain speakers..Based on how big screen you settle for, you might squeeze some space on either sides and use that to access behind the screen.. Just a thought..
