Apparently notyes correct
- Gain is changes in signal amplitude before the amplification it is not to be used as a loudness control and is actually manipulating how that signal will be handled during amplification and it is usually used in conjunction with other components to optimize the overall gain of the system based on the speaker/preamp used
- Volume control is After amplification and to be used for volume control
Details | Emotiva A300 | Audilab 8300XP |
Power Output | 150 watts RMS per channel; 20 Hz – 20 kHz; THD < 0.1%; into 8 Ohms. 300 watts RMS per channel; 1 kHz; THD < 1%; into 4 Ohms. | 140 W RMS (8Ohms <1%THD, 1KHZ stereo) 140 W RMS (8Ohms <1%THD, 1KHZ stereo) |
Gain | 29 DB | 29 Db @1KHZ Stereo |
Input Sensitivity | 1.2V | 1100mv |
Input Imepdance | 27 Kohms | 15K (balanced) 10K (Unbalanced) |
THD | <0.02% | 0.004% |
Price | 65K | 1.8L |
i agree but you can manage without a pre amp till you have funds to buy a nice one .. bass and treble can be adjusted on 2iApparently notGain is a whole different can of worms!
one last question to @jls001 and @arj -
The following are the specs for 2 power amps -
Details Emotiva A300 Audilab 8300XP Power Output 150 watts RMS per channel; 20 Hz – 20 kHz; THD < 0.1%; into 8 Ohms.
300 watts RMS per channel; 1 kHz; THD < 1%; into 4 Ohms.140 W RMS (8Ohms <1%THD, 1KHZ stereo) 140 W RMS (8Ohms <1%THD, 1KHZ stereo) Gain 29 DB 29 Db @1KHZ Stereo Input Sensitivity 1.2V 1100mv Input Imepdance 27 Kohms 15K (balanced) 10K (Unbalanced) THD <0.02% 0.004%Price 65K 1.8L
Now going by the specs - as the gain is 29db does this mean that Emotiva A300 will be a great match for the AL 6000A - purely from the point of view to understand the Specsheet. Not talking about he sound signature here at all.
What makes the AL8300XP so much more expensive? They are both A/B - similar power too.
Thanks Flux, never heard the INDIQ offerings, but I have seen how many here love it. That's always a good sign. Will speak with them and check what do they think about pairing with AL6000a.Do consider the Indiq Saptak over the Emotiva a300. It would cost you about 30k more but in exchange you will get an class AB dual monoblock power amp which is rated at 200 +watts @ 8 ohms, I preferred the Saptak over the Emotiva XPA-2 which seemed to have a brighter signature whereas saptak is more neutral.
Thanks @fLUX I am evaluating the Gold Saptak, as it has got plenty of power and no point making a complicated chain by adding the AL to the Power. Though just out of curiosity any suggestions for Pre matching if one goes for Platinum Saptak?
**Spoke to Amit, he is a great guy, extremely upfront and genuinely curious, no wonder he is liked so much.
Hey! I would still recommend your to go with Platinum. I have personally tried different pre amps with Saptak. Both SS and Tube and it pairs very well. Infact you can even run it directly from a DAC or even your phone using the 3.5mm to RCA converter.Thanks @fLUX I am evaluating the Gold Saptak, as it has got plenty of power and no point making a complicated chain by adding the AL to the Power. Though just out of curiosity any suggestions for Pre matching if one goes for Platinum Saptak?
Thanks the advice has been taken! I spoke to Amit and he was very sure that the amp can run directly through the Node 2i, apparently someone here on this forum did that as an audition. That solves my immediate requirement, I am very happy with the idea and as it is an extremely powerful amplifier, I am hoping this will serve me for years to come.Hey! I would still recommend your to go with Platinum. I have personally tried different pre amps with Saptak. Both SS and Tube and it pairs very well. Infact you can even run it directly from a DAC or even your phone using the 3.5mm to RCA converter.
I have paired with a Pass Labs Pre-Amp, Lyrita DHT Tube Pre, Yamaha Wxc 50, Marantz PM7001, Bravo Mini Tube HP Amp and some others which now I don’t recall. I would say this power amp pairs very well with any source and you will definitely enjoy.
I have heard both Gold Saptak as well as Platinum. Both are good in its own way but given the choice & budget I am all in for Platinum Saptak. They are too good i say.
Som
I have become a big fan of quad sound in the past few years, though S1 is the first speaker I ever bought, I have heard Quads a lot amongst friends and family. Sadly my quads are 84Db. I love playing music at low volumes while working and that with the AL6000a (another thing I absolutely love, a beautiful sounding amp), is kind of not possible with this kind of sensitivity. I have to pump it up by quite a bit and as I have extremely sensitive ears, I have to take a break every couple hours. I do not have this issue at all with my QAs as they can be beautiful at low volumes too. The aim was a hope that maybe the copious amounts of power might help with the low volume dynamics.
I hope my assumption is correct, more power, low volumes, better sound? Right?
In my opinion, good amps have less noise and lower output impedance. How that can affect the sound is very subjective. More power definitely helps in large listening space or with low efficiency speakers. A powerful amp can definitely avoid clipping, which can damage out speakers. Quality low volume sound is more the function of the speaker than anything else. Some speakers do not really open up until they reach certain amount of volume irrespective of the amp being used but since Saptak is tuned very well I don’t see a reason why it should not pair well. Again this is something an amp designer can answer in depth and since Amit is a designer himself, he would be well qualified to answer your question on how well his amp can drive the quads. Knowing him so far, I can say he is not someone who is out there to sell anything and everything, but to give that utmost level of satisfaction to customers for the products they buy from him. So you are in good hands.Thanks the advice has been taken! I spoke to Amit and he was very sure that the amp can run directly through the Node 2i, apparently someone here on this forum did that as an audition. That solves my immediate requirement, I am very happy with the idea and as it is an extremely powerful amplifier, I am hoping this will serve me for years to come.
If this is your beef, beg/borrow/steal any ifi product with their x-bas function and see if it works for the intended purpose. There is a possibility you might call off your search.I have become a big fan of quad sound in the past few years, though S1 is the first speaker I ever bought, I have heard Quads a lot amongst friends and family. Sadly my quads are 84Db. I love playing music at low volumes while working and that with the AL6000a (another thing I absolutely love, a beautiful sounding amp), is kind of not possible with this kind of sensitivity. I have to pump it up by quite a bit and as I have extremely sensitive ears, I have to take a break every couple hours. I do not have this issue at all with my QAs as they can be beautiful at low volumes too. The aim was a hope that maybe the copious amounts of power might help with the low volume dynamics.
