99% i have sorted out in my setup past 2 weeks. I am now looking for the last 1% improvement in my setup and have started working on that from todayFortunately I already have a system I am happy with. I now don’t fret over 1% improvement.
Oh, didn't know that an audition is impossible for you, guess i m spoilt living in a big city where auditions are easy.when you are in a far away places where there are no retailers? I am not crazy to go to Kolkata or Guwahati or Delhi to audition an amp/speaker for a silly hobby. My interest is not that much 'audiophile'.
2 pegs is the best upgrade to any music system, when i m down a few pegs, my Bose sound system sounds heavenThey sound even more fantastic and nostalgic after 2 pegs of fine whiskey ....when I go down roads of pink Floyd, CCR, ZZ top, led Zeppelin, and yes even gazals![]()
Depends on what you are expecting out of a tshirt. If it’s nailing the fit , then measure your torso, compare it with the dimensions of the tshirt your looking online and you know if it fits your body even without trying it out. Most companies have various useful dimensions of product.
Buy few tshirts with slightly different dimensions and try them which one is good on you. One you find the sweet spot, buy other tshirts with similar dimensions. You may not be disappointed by the fit.
Hear few speakers with different measurements and find the correlation between measurement and the real world sound and find out what combination of measurements favors your taste.
Next time when you are looking for a new one you can ignore the worst sounding ones from the measurements.
Well said, I Couldn't have put it any Better.I like gear that are build upon good measurements as a baseline. I have come to realise that only gear that goes beyond measurements into the subjective realm as well sound good to my ears. Science + Art. Science is something anyone can do. Plenty of designs out there. But the magic is when the Art comes into play. That is where the fun is and only reason to have this hobby. At least for me.
+1 to this. In my setup any type of fancy room treatment compltely screws my listening experience. They have always added to my problems than solving them. Room treatment compress my midrange and highs to much for my liking. Also any type of power conditioners and isolation transformer etc ruins my setup. Minimalist approach have always worked for my setup.There are showrooms that create these kind of environments. Minimal treatments on wall with just carpets etc. that mimics your home environment more or less. I have found such places to work reasonably well. Also most consumer loudspeakers have been voiced to work in such places rather than fully treated studio spaces.
perfectly summarized and its this balance between the two is where differences between equipment start coming upI have come to realise that only gear that goes beyond measurements into the subjective realm as well sound good to my ears. Science + Art. Science is something anyone can do. Plenty of designs out there. But the magic is when the Art comes into play. That is where the fun is and only reason to have this hobby. At least for me.
Very well said.Everyone's expectations and experiences differ; as long as you enjoy the journey and not be judgmental about others choices all is well.
Measurements are not just about room response. there is also areas like distortion /timing etc which no EQ can correct in fact may make it worseI have 1 more question - for education sake and not to rile anyone up - and not to start another random thread.
If one buys a well measuring speaker - then uses DSP and equalisers etc, to make them sound neutral in the room, you are technically changing the original measurement/SQ/parameters of the speaker right? So isn't the purpose of buying the speaker that measured great out of factory defeated?
Also - you can buy a speaker that sounds good to your ears or has generally favourable reviews by forum members and not just published reviewers and then use DSP etc to make it sound good in your room. Isn't it the same thing then?
Or am I missing something?
PS: though I can't stop anyone from replying - I can humbly request for reasonable answers.
That well measuring speaker will in all likelihood not measure the same in your room. You can extrapolate from there.If one buys a well measuring speaker - then uses DSP and equalisers etc, to make them sound neutral in the room, you are technically changing the original measurement/SQ/parameters of the speaker right? So isn't the purpose of buying the speaker that measured great out of factory defeated?
Hi Sir, great Q!I have 1 more question - for education sake and not to rile anyone up - and not to start another random thread.
Where we heard them or where those FMs heard them matters a lot...Also - you can buy a speaker that sounds good to your ears or has generally favourable reviews by forum members and not just published reviewers and then use DSP etc to make it sound good in your room. Isn't it the same thing then?
A well measuring speaker doesn’t have to be something that is having a flat FR out of the box. Instead if it has good direcvity and very low distortion, it’s possible to eq it to flat at a listening spot.I have 1 more question - for education sake and not to rile anyone up - and not to start another random thread.
I didn’t start this thread, this was a comment on another thread. One of the mods here thought it would be a good idea not to pollute the original thread.
But seriously Sir, since you started this thread, what would be your own personal learnings, which others could learn from?
Thank you for the explanation.Most of the times, I am finding that such discussions are in a limbic loop.
And we tend to mix some fundamentals interchangeably.
Personally for me (at the risk of sounding ad homineum/ad nauseum)
- Well measured means the designer and manufacturers have taken care to make the product. That’s an indication to me that they care for the science. And how their product sound fundamentally be made banking on the firm foundation of audio science (which obviously is and has been the technological evolution)
- Well measured means I have a reference (say an anechoic chamber) against which I can compare how the product will respond in my room. And if we are more educated towards measurements like spinorama, I can even estimate the room response/speaker resonance/distortions/spl without even auditioning the product (for eg for speakers)
- Well measured system chain means, I can reliably lower distortions starting from source to transducers. (Atleast in context of audio science of audio reproduction).
- Well measured may not mean audible difference.But it may make electronical difference in the electronics involved. Obviously audio research is an WIP, much like any science subject. However advances and updates are the forte from the ongoing researches. There are significant audio research which have laid the foundation of fundamentals of measurements in audio science. There are significant amount of researches which have highlighted the weakness of ‘subjective’ assessment’ and how psychoacoustics can be significant bias as a parameter. Our cochlea is a fine engineered organ, but our brain can be a messy audio processor. And like any living things, our cochlea has a time related functional performance. Whereas machine measurements has the potential of being exemplary unbiased.And much like any science, the methodology of measurements are still being researched. So in future newer and better measurements will come about.
- The audio industry has an accepted and consensus on standards of objective measurements. And this has come about without merits.
We can never know in absolute what we hear at each individual ears and percieve the sound. We can only compare with objective measurements of functional MRI scans, brain stem evoked potentials/electrical signals/auditory signals study of auditory complex of brain. However these measurement will still elude how we feel/perceive these sounds. Hence comes the study and researches of statistical studies of cohorts of listener. And much like any science, ‘ control trials ‘ (not exactly like clinical trials) has been done ……and things like harman curve has come about, and flat FR as the targetable response.
The variety of perspectives comes along because of our individual taste, preference, and perception.The problem with subjective assessment is that it is not reproducible - what a ‘expert golden ear’ hears and described subjective terms cannot be reliably assessed as being heard by other audiophile ears/consumer ears. When he says warmth - what degree of it is heard by untrained ears? How will that untrained ear know it? How will the untrained ear authenticate what the expert hears? Taken this way the expert assessment is nothing more than a heresay.
That’s how the rabbit hole…..it can be as deep as can be. Mix to this the manufacturers/dealers/consumers interest.
For us consumers, ti will be always healthy for us to ask and bank our decisions on measurements. It makes an onus on manufacturers to justify their claims. It will expose them if they lie. It will make them reputable as it can mean a transparency of their products.
No, I am not saying you did a mistake or you should not buy.Thank you for the explanation.
I do appreciate your highlighting the challenges of measuring what happens in the auditory pathways and the brain when we hear sounds and music.
Are you saying that going by the measurements I should not have bought these two components?
I have owned better measuring amps and DACs, but while they reproduced audio well, I did not like them as much as I like the imperfectly measuring components that I have now. I am curious to understand why.
Is it possible that the audio measurement experts are missing something that they don’t have the means to define and measure?
Is it possible in some cases that we use measurements to avoid components that measure well?
I really don’t know the answer to these questions; it’s intriguing.
I remind and comfort myself that I am listening to music, not measurements.
The converse is also true?Even though some like coloration and distortions in their music, it cannot be a generalisation.....nor a healthy standard for audio reproduction.
Many like the sound of tube amps and vinyl but they don’t measure well? Yes, the ‘colour’ that they add to the sound is enjoyable I’m sure.The converse is also true?
How many?Many like the sound of tube amps and vinyl but they don’t measure well? Yes, the ‘colour’ that they add to the sound is enjoyable I’m sure.
Let us acknowledge coloured sound and accurate Hi-Fi sound both have their fans. When we state our preferences we are stating our priorities- subjective sound preference or the idea of listening to equipment that measures well (both of which of course are absolutely fine).
Ahh, We have a better sweet sounding word for this. Blessed!......Using my AKG731 I find very difficult to hear any difference between the audio reproduction of my iPad/Oneplus Pro/Topping D90se+A90/Sabaj D5. listening to same songs on Apple Music lossless. (I am not an audiophile.)...
