For our fellow FM's i just browsed through our forum sections and find the LCD/LED/ or Plasma's are reportedly failing with one issue or another either during warranty or immediately after the warranty ends or few months after warranty ends.
Its unfortunate see such state of affairs in our so called Television series irrespective of the brands/models.
Everyone knows that from past couple of years (should we say from year 1999 onwards) manufacturers does little (or may be very little) on the quality control!! All those money which are drained on TV to get a wonderful experience does not last even for few years!
I have just compiled some - which may be use to FM's who would like to go through once before buying a new TV. (I am not propagating a negative image. But a one-time information what to look at before you open your wallet!!)
Samsung
http://www.hifivision.com/television/51103-samsung-f8000-white-light-bleeding.html
http://www.hifivision.com/television/51014-samsung-tv-dead-under-2-years-beware.html
http://www.hifivision.com/television/50258-lg-led-lw5700-software-problem.html
http://www.hifivision.com/television/50733-poor-quality-samsung-led-tv.html
http://www.hifivision.com/television/50630-defective-samsung-plasma-51-e550.html
http://www.hifivision.com/television/49616-samsung-led-panel-crashed-need-help-advice.html
http://www.hifivision.com/television/48932-panel-replacement-46ue6800.html
http://www.hifivision.com/television/48526-faith-no-more-samsung-led-ua40c5000.html
http://www.hifivision.com/televisio...ead-first-impressions-reviews-issues-etc.html
http://www.hifivision.com/television/47392-urgent-need-help-samsung-led-panel-problem.html
http://www.hifivision.com/television/31014-depreciated-buyback-samsung-plasma.html
http://www.hifivision.com/television/46470-samsung-ps51e550-plasma-vertical-line-issue.html
http://www.hifivision.com/television/45956-need-help-samsung-plasma-vertical-lines.html
http://www.hifivision.com/television/45944-samsung-lcd-tv-40-d500-image-separation-problem.html
http://www.hifivision.com/television/45776-repair-upgrade.html
http://www.hifivision.com/television/45739-samsung-40-es-6200-led-related-queries.html
http://www.hifivision.com/television/45130-panel-problem-my-samsung-ua405500-please-advise.html
LG
http://www.hifivision.com/television/50591-my-lcd-died-any-plasma-40k-full-hd-available.html
http://www.hifivision.com/television/47073-lg-tv-damaged-plz-help.html
http://www.hifivision.com/television/45741-issue-lm7600-need-help.html
Panasonic
http://www.hifivision.com/television/50747-panasonic-et50-bleeding.html
http://www.hifivision.com/televisio...ke-get-replacement-your-panasonic-plasma.html
http://www.hifivision.com/television/48446-panasonic-42et60-clouding-ghosting.html
http://www.hifivision.com/television/47022-panasonic-thou-too-lets-down.html
http://www.hifivision.com/television/48001-patches-glass-panel-my-plasma-pv8-d.html
http://www.hifivision.com/television/47612-panasonic-thl32e5d-panel-fault-15-months-old.html
http://www.hifivision.com/television/43351-loud-buzzing-noise-plasma-screen-broken-5-mths-old.html
Sony
http://www.hifivision.com/television/43715-problem-sony-bravia-screen.html
http://www.hifivision.com/television/49131-color-shadowing-problem-sony-lcd.html
http://www.hifivision.com/television/47836-sony-led-tv-showing-negative-green-images.html
http://www.hifivision.com/television/45710-need-help-defective-led-tv-delivered-sony-center.html
http://www.hifivision.com/television/46572-sony-40w900a-audio-issues-fresh-piece.html
http://www.hifivision.com/television/44806-sony-klv32nx500-projection-issue.html
Philips
http://www.hifivision.com/television/50589-one-more-victim-snapdeal-used-defective-tv.html
http://www.hifivision.com/television/49599-problems-philips-led-tv.html
NOTE: Those reported above are only products brought from India. The others (out-side) India are not listed here, which did have problems too (but ofcourse the percentage is very less).
The list reads too many of Samsung product issues. Oh!! I was one of those Samsung victims (of LCD) earlier!
At one point-of-time i was scouting for a new CRT TV instead of these new technology. But unfortunately almost all the showroom/dealers do not have any CRT's!
So i can think of is, no reliable TV (LCD/LED/Plasma's)!
Is there an option of having a TV tuner card (or similar), Projector, amp/speakers to take it forward. All these components in a budget affair! Or a better option to run away from LCD/LED/Plasma's!?
Samsung
LG
Panasonic
Sony
Philips
