^^ Don't forget fee for firmware upgrade.
How much generally it is
Has anyone faced any problem during the update?
The update usually will not fail. If it does, there are a few things you can check such as the size of the update file on disk and on the CD media. You can also check whether the CD was burnt in the ISO-9660 format. If you find either of these to be problems you can fix them and retry the firmware update. If it absolutely does not work after all that, you have the option of contacting the creator of the enhanced firmware.If the update fails somehow what to do or is there any reason to worry about this (may be I'm little scared as I've not done such thing before). I'm worried so much because I think firmware update will be the ultimate to buy the player from USA or other place.
I hope you'll understand what my concerns are.
How much generally it is? Amazon UK site is showing region free model but costly:sad:
Have not faced any such issue. My BDP is connected to HDMI 2 (ARC) of my ST50. I have set HDMI control in the BDP to ON. When the BDP starts to play something, the TV automatically switches to HDMI-2.I bought the player from Amazon and got it down through Borderlinx and upgraded to 1.49A from firmwareinfo. A problem I'm facing is that as soon as I on the player the TV switches to HDMI 1 input while the input cable is in HDMI 2 or 3. (Difficult to access HDMI 1 since its behind the TV). Have any of you faced this problem? Any help would be appreciated.
Gijo
The bonus of HDMI control is that when I switch off the TV or switch to HDMI 1 (TataSky STB), the BDP switches OFF automatically.
Gijo
BDT-220 is being offered by Amazon for $79.99.. great deal.. if someone is planning then he shall not miss it..
Ah damn.. Ordering it right now. :yahoo:
please note this is a 110V version.....
Please note that any voltage adapter does not work. Only a transformer based adapter will do.
http://www.mdrelectronics.com/ProductDisplay.asp?PID=1092
Again back to $92.99.. so the drop was only for a day.. may be they will offer the same or lower price again
